No Heat!! Itz Cold Out
Old Jan 18, 2007 | 07:29 PM
SPOONfed-Rex's Avatar
Default No Heat!! Itz Cold Out
Got a 91 Crx Si.. Car runs good but has no heat. The Car Warms up to operating temperature and i blast the heat...Jus cold air...Any Ideas What It Could Be??
Old Jan 18, 2007 | 07:57 PM
Mr. Giggles's Avatar
Default Re: No Heat!! Itz Cold Out (SPOONfed-Rex)
thermostat
Old Jan 18, 2007 | 08:10 PM
vw eater's Avatar
is the heater core bypassed?
Old Jan 18, 2007 | 09:41 PM
B16CRXT's Avatar
look under the dash and have someone turn the climate **** to see if the lever is moving. It is connect to a cable at the control unit. The other cable goes into the engine bay and connects to a heater lever near the firewall.
Old Jan 18, 2007 | 11:54 PM
Mr.Meowsome's Avatar
Default Re: No Heat!! Itz Cold Out (B16CRXT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">look under the dash and have someone turn the climate **** to see if the lever is moving. It is connect to a cable at the control unit. The other cable goes into the engine bay and connects to a heater lever near the firewall.</TD></TR></TABLE>
my cable is stuck from the inside so i unhooked it from the lever in the engine bay and pushed the lever to the wall which is the warm side
Old Jan 19, 2007 | 02:42 AM
Default Re: No Heat!! Itz Cold Out (hatchbacksweep)
I'm pretty sure the thermostat is good and the heater core has not been messed with...I will check the cables to see if they are stuck. If that doesn't work I guess ill end up doing what hatchbacksweep did
navin
Dec 16, 2007 10:04 PM
NJE94Ghatch
Oct 27, 2006 08:27 AM
Nataku
Sep 27, 2005 05:30 PM
yOnKiNaToR
Mar 11, 2005 04:12 PM
itsJDMyo
Oct 30, 2003 05:39 PM
