Erratic behavior at WOT
Old Jan 18, 2007 | 06:42 PM
vtec25's Avatar
Default Erratic behavior at WOT
at Wide Open Trottle it bogs really bad like flipping a switch on and off fast. But if let the gas go alittle bit up it than goes normal. i'm fluxuatin at idle too so i'm guessing its my TPS. what ya think?
Old Jan 18, 2007 | 06:45 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Erratic behavior at WOT (vtec25)
no cel?
Old Jan 19, 2007 | 01:23 AM
vtec25's Avatar
Default Re: Erratic behavior at WOT (Throwdown)
i got the CEL but its the Intake Air Temp sensor code. That cant be the reason though. Can it?
Old Jan 19, 2007 | 04:03 AM
Eran's Avatar
HT White Ops
Well, the IAT is one of the sensors related to determining A/F mixture. It could indeed be the culprit.
Old Jan 19, 2007 | 04:17 AM
bart2546's Avatar
Default Re: (Eran)
Agreed, if the code is throwing that, then that is most likely your culprit. As Eran stated, aside from the O2 sensor, the IAT is a very big decision making piece of equipment when it comes down to air and fuel mixture. First check to make sure the plug and wires are good, then make sure you're getting some kind of voltage to it. If you have both of those, time for a new IAT. Good luck !
VeeSykkz
14
Dec 16, 2014 07:31 AM
Eli Mac 67
Jun 8, 2007 02:30 PM
black sohc civic
Oct 30, 2005 07:02 PM
137
Mar 9, 2005 06:28 AM
red_sir
May 15, 2003 11:48 PM
