Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
headliner rattle...is there a quick DIY fix??
Old Jan 18, 2007 | 02:55 PM
japspecjohn's Avatar
Default headliner rattle...is there a quick DIY fix??
Its getting annoying and I dont have much time to bring it in to the dealer for this....any quick fix tips...I know its the headliner b/c When Im driving and listening to some mustic I push up on it and walllah vibration gone...thanks in advance!!
Old Jan 18, 2007 | 03:21 PM
Type X's Avatar
Default Re: headliner rattle...is there a quick DIY fix?? (japspecjohn)
where is is rattling from in the headliner?
stealerships usually "wedge foam" in there... so get crackin'
Old Jan 18, 2007 | 03:45 PM
Default Re: headliner rattle...is there a quick DIY fix?? (Type X)
towards the rear window ..good idea thanks budddy
Old Jan 18, 2007 | 03:55 PM
06BlackSi #45's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">where is is rattling from in the headliner?
stealerships usually "wedge foam" in there... so get crackin'</TD></TR></TABLE>
Yeah Good Idea. Mine is bad also. It was loose at first, but I just snaped it back. I'll go back and put some foam in.
Old Jan 18, 2007 | 05:42 PM
eL's Avatar
eL
I fixed the problem by replacing the 3 clips that hold the headliner on.
I have an annoying vibration coming from the A pillar on the passenger side. I push it in and it goes away.
Old Jan 18, 2007 | 06:27 PM
Demonis's Avatar
I'm going in saturday for my headliner and that OPDS recall thing. Just recently since it got cold, my passenger door (actually this started right after my whole car was covered in a quarter inch of ice) makes this sound like plastic on plastic rubbing... its driving me nuts!!!! If i had a week off I would just disassemble the entire inside of my car and foam pad it all.
Old Jan 18, 2007 | 07:22 PM
CrisEK's Avatar
Alright...here is the quick fix. I pulled the headliner from the rear and put 2 socks in between the roof and the liner. I have a Navi model and right under where the GPS reciever is I placed a sock there, and also in between the wire loom that connects to the reciever. PROBLEM IS SOLVED! No more rattle whenever I turn up the volume past 10!
Old Jan 18, 2007 | 08:44 PM
articsilber323's Avatar
my drivers seat every time i push back into it sounds like an old grandma chair
Old Jan 18, 2007 | 11:49 PM
skittle06's Avatar
Default Re: (articsilber323)
Anybody actually tried popping it in? Most people's it's just loose. Some others require the wedge.
Old Jan 19, 2007 | 02:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by articsilber323 &raquo;</TD></TR><TR><TD CLASS="quote">my drivers seat every time i push back into it sounds like an old grandma chair</TD></TR></TABLE>
yaa mines doing that **** now
Old Jan 19, 2007 | 03:42 PM
CrisEK's Avatar
If anyone has the headliner rattle, jus pop off the back part of the headliner and stuff sumthing in there. Foam, Cotton, whatever..(I used a couple socks. Even if you change the clips, that's not the problem to make the headliner stop rattling against the roof. The bass from the sub just makes the headliner vibrate. So when you stuff something in between to absorb the vibrating, your problem is solved. Trust me, the sounds are so much clearer and cleaner, no more annoying rattle when the bass hits. Hopefully this helps some people with this problem, unless I'm the only one with this problem....
H0ndas g0 Vr00m
Honda Civic (2001 - 2005)
11
Jan 30, 2008 06:48 AM
cookiemunster82
Honda S2000
Dec 22, 2007 10:44 AM
aws140
Jul 22, 2005 12:05 PM
IntegraGSR94
Aug 6, 2004 10:46 PM
MikeTV
May 29, 2003 10:40 AM
