Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Lx to SI
Old Jan 18, 2007 | 02:49 PM
elohel's Avatar
Default Lx to SI
So I've been talking it over with my dealer and it looks like it's going to cost me about $7,000 or so to trade my LX up to an SI, a 2007 Fiji blue Coupe. I have just a few questions on this, and yes, I did search It answered a few of my questions... So here we go.
1) What are some of the less-obvious differences between the base models and the SI? I mean besides things like the engine, tranny, limited-slip, etc?
2) Can this thing be driven on regular fuel without problems? I have no problem putting premium in it for a few cents more, but my wife is pretty adamant on believing the car doesn't NEED premium, so she refuses to fill up with that. Would there be any problems if she used that instead of premium?
3) The VSA the new 07's have is the only thing keeping me from buying a used 06 si on the lot. How well does this work? And can it be turned off? There are times when I would like there to be NO traction control. During the winter, however, I would want it on since even my LX spins tires like mad even on light acceleration.
4) How do you find the performance of the car to be in slick weather conditions, such as packed snow on the ground with the VSA? When I drive the wife's oddyssey with traction control, snow isn't a problem at all. I sit in the civic.. the wheels just spin, even with the pedal pushed in (stock tires, which is a large part of the prob).
Old Jan 18, 2007 | 02:53 PM
Type X's Avatar
Default Re: Lx to SI (elohel)
Suspension, Interior,Exhaust note, Exclusive colors
If your already trying to be a cheap *** ... just keep the LX, using regular fuel will eventually give you a CEL the car is required to have specific fuel..use it.
[b] Regardsless of VSA or not.. in snow.. you will have SOME issues... it will cut some power in slipping situations but nothing Insane.[/b[
I have an 06'.. no clue
Old Jan 18, 2007 | 02:57 PM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elohel &raquo;</TD></TR><TR><TD CLASS="quote">1) What are some of the less-obvious differences between the base models and the SI? I mean besides things like the engine, tranny, limited-slip, etc?</TD></TR></TABLE>
The Si has horsepower, an amazing 6 spd tranmission, serious brakes, LSD, electronic power steering, performance oriented suspension, red display(s), sportier interior, and small other ques that make it MUCH more exciting than a base model.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
2) Can this thing be driven on regular fuel without problems? I have no problem putting premium in it for a few cents more, but my wife is pretty adamant on believing the car doesn't NEED premium, so she refuses to fill up with that. Would there be any problems if she used that instead of premium?</TD></TR></TABLE>
I would ONLY run 91+ octane but if you decide to put a lower grade fuel in the ECM will notice it and compensate the timing in order to prevent detonation. Just run 91+ tho!!!
3) The VSA the new 07's have is the only thing keeping me from buying a used 06 si on the lot. How well does this work? And can it be turned off? There are times when I would like there to be NO traction control. During the winter, however, I would want it on since even my LX spins tires like mad even on light acceleration.</TD></TR></TABLE>
Yes the VSA can be turned off. It works quite well under certain conditions and can save your *** on some ocassions.
4) How do you find the performance of the car to be in slick weather conditions, such as packed snow on the ground with the VSA? When I drive the wife's oddyssey with traction control, snow isn't a problem at all. I sit in the civic.. the wheels just spin, even with the pedal pushed in (stock tires, which is a large part of the prob).</TD></TR></TABLE>
My Si doesnt have VSA but I imagine that with the proper tires and the VSA on you wont have a problem in the snow. My si(even on SUMMER tires) does suprisingly well... the ABS/EBD do a great job.
Old Jan 18, 2007 | 02:59 PM
TRE_'s Avatar
Default Re: Lx to SI (TRE_)
dayumn mike,,,, youre way to quick ho!
Old Jan 18, 2007 | 03:02 PM
Beefkake's Avatar
Default Re: Lx to SI (Type X)
well probably the least noticeable difference for the Si, is that there is a thin strip of amber round the bulb in the headlights. You can see it here.
There are a lot of small differences though. Trust me when I say this, if you get an Si you will love it.
Old Jan 18, 2007 | 03:03 PM
elohel's Avatar
Thanks X and Tre. You guys really are all over these forums
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">If your already trying to be a cheap *** ... just keep the LX, using regular fuel will eventually give you a CEL the car is required to have specific fuel..use it.</TD></TR></TABLE>
That's all I needed to hear lol
Thanks as well kake.
Old Jan 18, 2007 | 03:19 PM
Rahxephon's Avatar
If you not happy with your LX just it in.....don't foget to go with 4 dr Si cuz lot of JDM options.
Old Jan 18, 2007 | 03:21 PM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">dayumn mike,,,, youre way to quick ho! </TD></TR></TABLE>
Old Jan 18, 2007 | 03:42 PM
elohel's Avatar
Default Re: Lx to SI (Rahxephon)
One of the reasons (among a refined engine, 6 spd tranny, lsd, etc) is that I can switch from a 4 door to a coupe. The 4 doors just look plain ugly to be. If they just fixed the rear-end of it...
Old Jan 18, 2007 | 04:07 PM
Rahxephon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elohel &raquo;</TD></TR><TR><TD CLASS="quote">One of the reasons (among a refined engine, 6 spd tranny, lsd, etc) is that I can switch from a 4 door to a coupe. The 4 doors just look plain ugly to be. If they just fixed the rear-end of it... </TD></TR></TABLE>
Here's what i'm talking about https://honda-tech.com/zerothread?id=1868047
Old Jan 18, 2007 | 04:23 PM
elohel's Avatar
Yeah that Mugen civic is quite hot, but somehow I just don't see that being feasible to me.
Old Jan 18, 2007 | 05:03 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elohel &raquo;</TD></TR><TR><TD CLASS="quote">my wife is pretty adamant on believing the car doesn't NEED premium, so she refuses to fill up with that.</TD></TR></TABLE>
hurry, i'll draw up the divorce paperwork.
Old Jan 18, 2007 | 05:11 PM
RICO_'s Avatar
NO MERCY!
Default Re: Lx to SI (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elohel &raquo;</TD></TR><TR><TD CLASS="quote"> but my wife is pretty adamant on believing the car doesn't NEED premium, so she refuses to fill up with that. Would there be any problems if she used that instead of premium?
Problems? Yes as X stated the car NEEDS premium. You should probably stick with the LX then if it's gonna cause tension between you and your lady.
Old Jan 18, 2007 | 05:26 PM
elohel's Avatar
Default Re: Lx to SI (RICO_)
Ehh, I think I might get more action in the SI.
Haha kidding, but don't tell the wifey that I guess I just won't let drive the car if she can't put premium in it.
Old Jan 18, 2007 | 05:58 PM
mInI m3 Hondeezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elohel &raquo;</TD></TR><TR><TD CLASS="quote">Ehh, I think I might get more action in the SI.
Haha kidding, but don't tell the wifey that I guess I just won't let drive the car if she can't put premium in it.</TD></TR></TABLE>
Good choice.
Old Jan 18, 2007 | 06:18 PM
Demonis's Avatar
- Subtle differences also, orange halos in the lights, wheels, power steering i believe is different. sound system is better than DX/LX.... the rear brake light is in the wing, not in the glass...
- If its YOUR car, she should respect it, if its both of your cars, you need to explain to her that it is DESIGNED for higher octane fuel, explain to her what OCTANE is, and how it works in the engine.
- We just had a huge (i say huge, huge for texas) winter storm come through here, and while Ive NEVER driven in ice before, I had no problem maintaining control in my 06 si... i spun my tires very slightly when taking off, but if you know how to control your revs and let the engine do all your braking, you dont need VSA or special tires... though they help... Oh, and im running on the already poor traction summer tires.
Old Jan 19, 2007 | 02:32 AM
RICO_'s Avatar
NO MERCY!
I feel ya man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elohel &raquo;</TD></TR><TR><TD CLASS="quote"> I guess I just won't let drive the car if she can't put premium in it
Have her bring home a receipt just in case. Can't be to careful these days.
Old Jan 19, 2007 | 03:52 AM
Errorich's Avatar
I use the VSA pretty much all the time. At first the "VSA" button threw me off. I've been in a couple 06 si's and I didn't remember seeing it there til I got my 07. The 07 also has different floor mats, and slightly(and i mean VERY slightly) darker rims.
Going from the lx to the si you'll also notice the steering is much tighter. Notice the leather wrapped steering wheel too.
Old Jan 19, 2007 | 09:39 AM
elohel's Avatar
Default Re: Lx to SI (Errorich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Errorich &raquo;</TD></TR><TR><TD CLASS="quote">Going from the lx to the si you'll also notice the steering is much tighter. Notice the leather wrapped steering wheel too. </TD></TR></TABLE>
Ok that right there pretty much seals the deal
I HATE the steering wheel on my LX, it feels like crappy foam, and I cringe every time I accidentally slide my hand across it when I turn. Feels like I'm gonna rub off little ***** of foam or something
Old Jan 19, 2007 | 09:46 AM
Type X's Avatar
I HATE the steering wheel on my LX, it feels like crappy foam, and I cringe every time I accidentally slide my hand across it when I turn. Feels like I'm gonna rub off little ***** of foam or something </TD></TR></TABLE>
Change in the Si steering wheel ( about 80 from honda)
and save yourself the 7k
Old Jan 19, 2007 | 02:02 PM
elohel's Avatar
and save yourself the 7k</TD></TR></TABLE>
I was kidding
If the wheel added a 6sp tranny and 60 more hp to my car, then I would go with that.
Kentagious
18
Sep 25, 2007 10:40 AM
TRE_
46
Mar 24, 2007 05:34 PM
SacrificeTheory
12
Aug 30, 2006 03:11 AM
Xelnaga
12
Jun 2, 2006 06:54 PM
