car wont start
Old May 15, 2002 | 04:59 PM
H23 Power's Avatar
Default car wont start
90 accord, lx, auto tranny
fuel is being dumped, engine is turning...spark plugs not sparking
repleced the main relay and the ignitor...what is the problem????
Old May 15, 2002 | 05:18 PM
scrubachu's Avatar
Default Re: car wont start (01GSR)
plug wires??
Old May 15, 2002 | 05:52 PM
H23 Power's Avatar
Default Re: car wont start (scrubachu)
i doubt all 4 would go bad at the same time...
if one was bad it would still start
Old May 15, 2002 | 06:20 PM
BreakStuff's Avatar
New User
check and see if you have a constant 12 volts going to the coil.. if so, check for spark coming out of the coil while cranking the motor.... kinda tricky if its located in the distributor housing, but still can be done..
voltage to the coil and a no spark condition could possibly mean a bad coil.. there are other possibilities as well.. if you still need help, then direct this post to the "tech" forum.. GL..
Old May 15, 2002 | 06:26 PM
H23 Power's Avatar
Default Re: car wont start (BreakStuff)
the coil is the last thing we need to replace...but i thought i'd ask before we did that...
how much is a coil from auto zone?
Old May 15, 2002 | 06:27 PM
4doorH22's Avatar
BreakStuff RULES!
Old May 15, 2002 | 06:37 PM
SOHCArchangel's Avatar
Default Re: car wont start (4doorH22)
BreakStuff RULES!
Old May 15, 2002 | 06:38 PM
poison's Avatar
is the rotor inside of the dist turning? check ICM too
Old May 15, 2002 | 07:05 PM
RUBZERK's Avatar
Default Re: car wont start (poison)
YOU HAVE TO ADD MORE HAMSTERS UNDER THE HOOD TO GET IT KICKING OVER
Old May 15, 2002 | 07:18 PM
Gennady's Avatar
New User
Default Re: car wont start (RUBZERK)
Reset ECU. Worked for me.
Old May 16, 2002 | 01:17 AM
H23 Power's Avatar
noobies aren't allowed to be funny, sorry
Old May 16, 2002 | 06:20 AM
Chiovnidca's Avatar
The fuel injectors wont squirt fuel unless the igniter is sending a signal to the ecu. If you pull both wires off the coil and connect a test light between them, the light should flash when cranking the engine. If it does, and you were not getting spark off the coil, you have a bad coil.
Old May 18, 2002 | 05:11 PM
H23 Power's Avatar
Default Re: car wont start (Chiovnidca)
it was the ignition coil
Old May 18, 2002 | 05:32 PM
basically
swisscheese32
May 27, 2011 05:08 PM
dc2gsr96
Jan 18, 2010 11:15 AM
AzntaggeR
Feb 25, 2004 12:02 AM
crxzc
Jun 9, 2002 06:50 PM
Big_b_69er
Jan 24, 2002 09:07 AM
