low beam not working on driverside
Old Jan 17, 2007 | 04:34 PM
lsvtecej6's Avatar
Default low beam not working on driverside
what do u think it is i checked fuses and they are good low beam works on passenger side but not drivers side and bulbs are brand new any ideas of what it could be
Old Jan 17, 2007 | 04:35 PM
lsvtecej6's Avatar
Default Re: low beam not working on driverside (lsvtecej6)
info on the car its a 96 hatch with 2000 front
Old Jan 17, 2007 | 04:43 PM
pdiggitydogg's Avatar
Did you look at the low filament on the driver bulb? It may be bad, even though its new
Old Jan 17, 2007 | 04:51 PM
nicko360's Avatar
* B A N N E D *
double check the fuse and bulb, the high beam fuses and low bem are sometime in different places (under hood and under steering wheel)
Old Jan 17, 2007 | 06:01 PM
solerizr's Avatar
Default Re: low beam not working on driverside (nicko360)
I had this problem in my car.... turned out to be the connection between the bulb and wiring harness.... try some dielectric grease, or fiddling with the prongs.
Old Jan 17, 2007 | 06:04 PM
egmatt93's Avatar
Default Re: low beam not working on driverside (solerizr)
had the problem as well before... turned out to be a bad bulb..just a suggestion
n/m u have new bulbs :/
Old Jan 18, 2007 | 05:32 PM
lsvtecej6's Avatar
Default Re: low beam not working on driverside (egmatt93)
thanks for the help gonna try that **** tomorrow
well this is the story i wired my fogs in to my headlights cause switch went bad on the passenger side foglight the prongs came out of the passenger side foglight clip and touched and blew my fogs land head light on passenger side i changed bulbs and still no low beam
Old Jan 18, 2007 | 05:58 PM
JdmEj1!'s Avatar
OMFG the same **** is wrong with my 95 coupe right now too! AHAAHAH i cant figure the **** out either! I checked fuses, rewired a ground real quick, even clean the connector... i still have nothing! Hopefully one of us can get an answer and some help
Old Jan 19, 2007 | 04:28 PM
lsvtecej6's Avatar
Default Re: low beam not working on driverside (JdmEj1!)
pr1madona
Honda CR-V & Element
Oct 1, 2016 11:52 AM
jtthwaits
Mar 5, 2011 05:40 PM
graywzc
Oct 13, 2007 05:55 PM
Night Kid
Sep 12, 2001 08:42 PM
