rotor surface on my R
Old May 15, 2002 | 04:11 PM
EleanoR's Avatar
Default rotor surface on my R
I was checking the air pressure in my tires tonight and noticed that on the drivers side front rotor there is an indentation that is sorta deep to me on the rotor surface. I just put the Carbotech Panter + pads on getting ready for the event this weekend. None of the other rotors have anything like this at all. I was wondering what could of caused this? Like i said it seems to be pretty deep on the surface. My brakes have been squealing like hell lately which i knew they would with the Carbotech's...but even with them warmed up they squeek. Heck, even driving down the road and not even applying the brakes they sqeak. Is this normal?
Mike
_______
Old May 15, 2002 | 05:47 PM
SpiceyRice's Avatar
Default Re: rotor surface on my R (talkie25)
Sounds like you've grooved your brake rotor - don't worry, Brembo blanks are $38, so it's no big deal.
Check to make sure your front pad is seated properly. There shouldn't be more wear on one rotor than the other (the fronts should wear the same as each other, the rears should wear the same as each other). Plenty on meat left on your pad too I assume?
Old May 15, 2002 | 06:41 PM
96 SOHC VTEC's Avatar
Mike
_______
LMFAO! Oh boy! And I get to ride two hours in this!?
Old May 16, 2002 | 03:40 AM
EleanoR's Avatar
Default Re: rotor surface on my R (96 SOHC VTEC)
No the squeaking stops by 60 mph
jxhxb
Aug 14, 2008 02:17 PM
thaseint
Suspension & Brakes
May 1, 2007 09:45 PM
FORTIS
Oct 2, 2002 04:47 PM
EleanoR
May 15, 2002 08:19 PM
fso_BamBam
Jun 16, 2001 11:08 AM
