si cam from a 91 civic will fit on 98 civic dx motor?
Old Jan 17, 2007 | 03:42 PM
stevescivic's Avatar
Default si cam from a 91 civic will fit on 98 civic dx motor?
I have a 91 civic si cam shaft and cam gear and I wanted to know if it would be a direct bolt on into my 98 honda civic dx hatch.
Some ppl have said yes no problem and some ppl say no it will not work. What is the real answer?
What cam gear do I use?
Thanks
Old Jan 17, 2007 | 04:00 PM
Syndacate's Avatar
Default Re: si cam from a 91 civic will fit on 98 civic dx motor? (stevescivic)
I'm not positive, but I'm pretty sure all D series camshafts are interchangeable.
Old Jan 17, 2007 | 04:01 PM
highrev1987's Avatar
Default Re: si cam from a 91 civic will fit on 98 civic dx motor? (Syndacate)
bump for second opinion
Old Jan 19, 2007 | 05:59 PM
Default Re: si cam from a 91 civic will fit on 98 civic dx motor? (highrev1987)
bump.
nobody?
Old Jan 20, 2007 | 06:33 AM
MrPotatoeHead's Avatar
Yes the Si cam will fit the non vtec head, except the y series.
Old Jan 20, 2007 | 07:32 PM
Default Re: si cam from a 91 civic will fit on 98 civic dx motor? (MrPotatoeHead)
okay I'm a bit rusty here but what is the Y head?
is that from an Si Vtec?
The thing is that I want to install an 91 Si cam into my 98 DX but I'm not sure if i have to screw with the cam timing or that it will be a perfect fit. Based on your answer I think i can safely say that i can drop the cam in without a problem?
thanks
Sheep
29
Apr 2, 2007 11:01 PM
stevescivic
Jan 31, 2007 08:49 PM
tgreaves
Nov 14, 2003 10:18 AM
1CiViC1
Jul 17, 2003 01:07 AM
dgonzals
Jul 7, 2003 05:28 PM
