Battery charging issues
Old Jan 17, 2007 | 10:01 AM
b16a1eg6's Avatar
Default Battery charging issues
I have a 1997 Civic DX. When the car is running the volt meter I have show only 12.8 volts. When all lights , heater, rear defrost, and wipers are on it goes down to around 11.9-12.2 volts. I changed the altenator. Changed the fuse box to replace the load sensor. It still has the problem. Any ideas?
Old Jan 17, 2007 | 10:09 AM
BBY98EX's Avatar
Default Re: Battery charging issues (b16a1eg6)
have you checked battery and the battery cables?
Old Jan 17, 2007 | 11:48 AM
melnkay's Avatar
Default Re: Battery charging issues (BBY98EX)
check battery and cables...
no corrosion on terminals right..
Old Jan 18, 2007 | 08:05 AM
b16a1eg6's Avatar
Default Re: Battery charging issues (melnkay)
new battery and cables are nice and clean
Old Jan 18, 2007 | 08:14 AM
pdiggitydogg's Avatar
How is the tension on the alternator belt?
Old Jan 19, 2007 | 07:33 AM
b16a1eg6's Avatar
Default Re: (pdiggitydogg)
It has a little bit of give to it.
Old Jan 19, 2007 | 08:38 AM
bart2546's Avatar
Default Re: (b16a1eg6)
See how much give, if we're talking give to the point that it's slipping...then it's not gonna turn and charge like it should. Maybe tighten it a bit.
Old Jan 19, 2007 | 01:18 PM
gents97civ's Avatar
Check the vss/alt fuse under the dash. Also check the alt plug for corrosion and fit. I would use some dielectric grease on it as well.
Old Jan 19, 2007 | 03:10 PM
BubblegumTate's Avatar
Default Re: (gents97civ)
2nd vote for check that VSS/ALT fuse. I think it's #15 if memory serves.
Had the same problem with my wife's 98 LX. Ended up being a wire in a harness way up under the intake mani that had rubbed so long that the insulation was gone and was shorting to ground, blowing that fuse every time. A little heat shrink and taping the harness up to keep it from rubbing and we were good to go.
alperx
Nov 27, 2012 05:47 AM
toner297
Honda Civic (2001 - 2005)
12
May 24, 2011 12:39 AM
Ruben19
Oct 10, 2007 08:49 AM
metalgears
Feb 18, 2006 01:43 PM
DiSbaDbOi
16
Jan 5, 2005 07:24 PM
