abs light keeps turning on after i replaced my front brake pads and rotors
Old Jan 17, 2007 | 05:48 AM
92preludesi2.3's Avatar
Default abs light keeps turning on after i replaced my front brake pads and rotors
hey,
my abs light keeps turning on after i first start driving. This started to happen about 2 weeks after i replaced my front brake pads and rotors, do you guys have any ideas to why this would happen.
Old Jan 17, 2007 | 06:23 AM
Turbocivic94's Avatar
Default Re: abs light keeps turning on after i replaced my front brake pads and rotors (92preludesi2.3)
check ur sensors. I had to replace both rear sensors cause they were broken. U can check codes by jumping the wire for ses light. just watch how many times it blinks.
Old Jan 17, 2007 | 08:00 AM
Default Re: abs light keeps turning on after i replaced my front brake pads and rotors (Turbocivic94)
where are the sensors located? Are they on the calipers?
Old Jan 17, 2007 | 08:58 AM
Hawkze_2.3's Avatar
Look for the orange connectors, they are all ABS lines. I believe the sensors mount to the knuckle and point at the little notches on the outer end of the axles.
Old Jan 17, 2007 | 06:44 PM
they're on knuckles. you can test if sensors are bad by volt meter. I would check codes before doing anything else.
Eric Buschman
Honda CR-V & Element
Jun 1, 2013 10:01 AM
Baron55
Jun 14, 2008 05:13 AM
socialistic
Jan 18, 2008 05:09 AM
HarryPotter
Dec 19, 2004 05:56 AM
gstintegra92
Aug 7, 2003 08:24 PM
