ABS Light
Old Jun 12, 2008 | 05:59 PM
Baron55's Avatar
Default ABS Light
So, I have been on warped rottors for a while and needed new pads for a few weeks. I changed them recently but prior to the change I hit a high speed and had to brake a bit hard; the car was vibrating a lot due to the warped rottors and the pads were done, it was making a grinding noise at that point...Anyways, the ABS came on and stayed on after I got new pads and rottors, disconnected my battery to try and reset the light...Any ideas?
Old Jun 12, 2008 | 06:26 PM
JEGD16Z6's Avatar
Default Re: ABS Light (Baron55)
check for codes...
Old Jun 13, 2008 | 03:48 AM
Dogginator's Avatar
Daisy... Daisy...
Check the codes (see the FAQ thread for a link). The grinding may have released metal, which can stick to the wheel speed sensor and cause it to fault. If so, they can be cleaned.
Old Jun 13, 2008 | 10:05 AM
alex711's Avatar
does your car by any chance while idling after 5 minutes or so make a loud humming noise...for about 4 or 5 seconds then stop? if so it is your abs motor.. mine went out, and they are common to go out. the abs light will come on randomly and go off each time you turn your car off unless its a sensor, in which case it sounds like your light is always on.. so i bet the guy above is right... if it stays on after turning your car off its deff not ur abs motor.
Old Jun 13, 2008 | 03:58 PM
JuggsxCOmanDO's Avatar
clean your wheel speed sensors, that should be it
Old Jun 13, 2008 | 08:21 PM
Baron55's Avatar
I will attempt to clean the sensors first, but.......where exactly are they?
Old Jun 14, 2008 | 05:13 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Baron55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">I will attempt to clean the sensors first, but.......where exactly are they?</TD></TR></TABLE>
Why guess? Pull the codes.
strukaccord
Suspension & Brakes
Nov 13, 2008 11:43 AM
socialistic
Jan 18, 2008 05:09 AM
LudeBehavi0r
May 4, 2006 05:43 PM
jdmlude_dude
Mar 16, 2004 06:01 PM
