SOHC w/P72 OBD II
Old Jan 17, 2007 | 04:20 AM
4thgenx42's Avatar
Default SOHC w/P72 OBD II
My friend just bought a 99 EX coupe. Yesterday he gets a check engine light. We run the code and it says that the ECM/PCM is malfunctioning. The problem is he needs a new computer, but he has a P72 OBDII computer sitting at home. My question is if that computer can be used to run the SOHC motor in his 99 EX? Thanks!
Old Jan 17, 2007 | 04:33 AM
EJ1_203's Avatar
Default Re: SOHC w/P72 OBD II (4thgenx42)
yes it will run a little better but probably more on the rich side than usual!
Old Jan 17, 2007 | 10:29 AM
Blk00EJ8's Avatar
Default Re: SOHC w/P72 OBD II (EJ1_203)
How would richening an already rich mixture make it "run a little better?"
In theory you could make the P72 work, but it'll run rich as hell. There's no use anyway since the D16 and the B18C are completely different.
Oh yea, and it depends on what year P72 it is. 00-01 USDM P72s are equipped with immobilizers so if it doesn't find the transponder in your key, which it won't because it's a Civic key, then your fuel pump will be cut and you can't start the car.
Old Jan 17, 2007 | 10:48 AM
EJgsr's Avatar
Default Re: SOHC w/P72 OBD II (EKcivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKcivicEX &raquo;</TD></TR><TR><TD CLASS="quote">How would richening an already rich mixture make it "run a little better?"
Oh yea, and it depends on what year P72 it is. 00-01 USDM P72s are equipped with immobilizers so if it doesn't find the transponder in your key, which it won't because it's a Civic key, then your fuel pump will be cut and you can't start the car. </TD></TR></TABLE>
thats some good info i did not know that.
Old Jan 17, 2007 | 06:13 PM
4thgenx42's Avatar
Thanks for all the helpful info...
Built_Fast
Jun 28, 2007 07:02 PM
kobeRy_si
May 27, 2005 02:02 PM
lsvtec101
May 29, 2004 07:52 AM
civicdohc
May 25, 2004 03:27 PM
HXvtec
26
Sep 15, 2003 10:21 PM
