Idle drop and noise
Old Jan 16, 2007 | 07:12 PM
96JDMTEGAZ's Avatar
Default Idle drop and noise
I have a question....
Ok I have a 96 Integra w a B20B swap and everytime I start my car I hear a noise coming from the passenger side of the car. When the noise is apparent, the idle drops a bit and then picks back up. It does this only when it needs to I guess....I believe it is coming ABS but I'm not positive, can anyone help me out?
Thanks
Old Jan 16, 2007 | 08:18 PM
JimBlake's Avatar
Default Re: Idle drop and noise (96JDMTEGAZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96JDMTEGAZ &raquo;</TD></TR><TR><TD CLASS="quote">... I hear a noise coming from the passenger side of the car...</TD></TR></TABLE>Can you narrow that down some more? The ABS modulator unit is near the right headlight, you can have someone listen in the engine bay when you start it.
Old Jan 17, 2007 | 02:19 AM
Richard...'s Avatar
Default Re: Idle drop and noise (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Can you narrow that down some more? The ABS modulator unit is near the right headlight, you can have someone listen in the engine bay when you start it.
while your thinking about the ABS might as well remove it lol unless of cause you feel you need it
never cared for ABS on any car is is as annoying as P/S just a suggestion!
Old Jan 17, 2007 | 08:12 AM
96JDMTEGAZ's Avatar
Default Re: Idle drop and noise (richard7968)
Yes that is where it is coming from....is there any way to lubricate it or anything?
Any suggestions?
Old Jan 17, 2007 | 01:19 PM
JimBlake's Avatar
It's a canned pump, you can't lubricate it. You could bleed the ABS but that probably won't make a difference. It's a high-pressure pump so it isn't gonna be silent. Hard to say without hearing yours firsthand, but it's a pretty clear buzzing noise. Not very subtle.
My '95 Integra always made that noise, normally for about 5 seconds at startup. The idle control system pretty much handled it & there was very little disturbance in idle RPM. The electric power it takes is measured by the ELD, so that's how the ECU knows how to handle the idle control.
If the ABS controller decides that the pump runs too long or too often, it'll set off the ABS warning lamp. I don't know whether it has any other means to measure the 'health' of the pump.
Old Jan 17, 2007 | 08:22 PM
96JDMTEGAZ's Avatar
ya very true it is a noise apparent at start up but at the same time it comes on when it believes it needs to i guess...and the ABS light has been on for miles....so I'm just thinking whats the best way to fix this problem....
Old Jan 17, 2007 | 09:15 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96JDMTEGAZ &raquo;</TD></TR><TR><TD CLASS="quote">...and the ABS light has been on for miles...</TD></TR></TABLE>
FIRST - Read the error codes from the ABS. Jumper the SCS connector, just the same one that you use for check-engine light codes. But the ABS light will flash its code. The syntax of flashes is different tho; there's no long flashes in the codes...
Here's a thread from the Integra forum about error codes. Scroll down past the engine error codes, then you'll see something with my name at the top...
https://honda-tech.com/zerothread?id=978933
Post up what it flashes & we'll go from there.
7andaswitchblade
Jun 23, 2007 08:53 PM
Blk-dc2
Oct 28, 2006 02:42 PM
Finger Lickin' good
Nov 23, 2005 04:30 AM
one^g
Sep 10, 2005 07:51 PM
SAVAGE99
Jan 16, 2004 09:46 AM
