vacuum leak at master cylinder/brake booster?
Old Jan 16, 2007 | 07:10 PM
dxhatch92's Avatar
Default vacuum leak at master cylinder/brake booster?
theres a noticeable hissing sound of a vacuum leak near the bottom of the master cylinder/brake booster. would problems would that cause? and also what would i need to fix the problem
Old Jan 16, 2007 | 07:15 PM
Zeusfire69's Avatar
Default Re: vacuum leak at master cylinder/brake booster? (dxhatch92)
You will probly have to replace the brake booster. You will have a really stiff pedal, and your brakes will not stop you well without alot of pressure.
In other words, there is eather a leak in your brake booster or you just have a crack/cut in the vacuum line going to it.
PS..if you have zero money, and there is a crack in the booster itself, sometimes JB weld or even duct tape will work as a temp fix.
Old Jan 16, 2007 | 08:13 PM
dxhatch92's Avatar
i see, ima try to find the leak and jb weld it first to see if it stop haha thanks for the help!
upsidedown
Jul 27, 2015 09:51 AM
ZippyZivic
Mar 24, 2009 07:58 PM
Specail Ed
Mar 31, 2008 08:25 AM
haophat
Oct 4, 2005 11:16 AM
MrEg
Sep 22, 2003 04:49 PM
