need some help on h23 turbo setup...
Im in the process of building my h23 for alot of boost. (20-25psi) I have darton MID sleeves, custom pistons 89mm (9:1) to fit eagle h22 rods, balanced crank, tri-flow re-cut colt cams, JGE engineering complete valvetrain(dual springs, stainless valves, titanium bases and retainers), ported head, ported intake manifold.
I am hoping to get 450-500 whp
This car will not be a daily driver, it is goin to be a weekend toy.
I am not going to have a/c.
Question(s)
1 What size injectors do you guys suggest? I was going to get 1000cc from msd.
2 What type of turbo manifold do you guys suggest? Cast or tubular, and from whom?
3 What size wastegate? Intnernal? External?
4 What do you guys suggest for fuel system (fuel pump, stock fuel line?, what brand FPR?)
5 What clutch? I was lookin at a few different 6-plucks (exedy, competition clutch)
6 Which hondata do you guys suggest? s100, s200 or s300?
I know I have alot of questions, but every little opinion will help.
Thanks!
Question(s)
Thanks!
1 What size injectors do you guys suggest? I was going to get 1000cc from msd? Yes 1000c are fine RC's are good to.
2 What type of turbo manifold do you guys suggest? Cast or tubular, and from whom? Definitely a tubular. Get an equal length manifold. Run a ramhorn. Spoolin performance & fullrace are
3 What size wastegate? EXTERNAL 38mm, TIAL only
4 What do you guys suggest for fuel system (fuel pump, stock fuel line?, what brand FPR?) Walrbo 255 will work fine. Stock fuel lines are fine.
5 What clutch? 6puck clutch. clutchmasters
6 Which hondata do you guys suggest? s300 all the way. neptune is bomn to.
Precison 1000cc injectors
Equal Length. - LoveFab is good for H23 set-ups
44mm if you can afford it
Walbro 255 as stated already. Stock FPR works just fine
ACT 6 puck ftw!
Hondata s300
Let me know if you need any of these parts... we have them all in stock
ACT 6 puck ftw!
Hondata s300
dep22build
Mid-Atlantic (Sales)
13
Dec 18, 2009 12:47 PM
