installed ebay short shift adapter (6th gen) PICS
i got this short shift adapter today:
http://www.silverimageracing.com/pd_9899_honda.cfm
i actually got it though their ebay store (which doesn't have any at the moment):
http://cgi.ebay.com/ebaymotors...d=1,1
it was shipped very quickly (paid late wednesday night, and it arrived the next
tuesday, monday was a holiday). it came in a small box stuffed with newspaper.
the adapter had no packaging! it was just in a zip lock bag along with a hex
wrench.
it was installed like these instructions:
http://syclone.motocrew.com/CG5/dcss.htm
i have no idea what the nut (shown in the pic attached to the bolt) is used for.
it does not fit on the stock bolt, so i used the stock nut (removed the
washer).
the bolt it comes with was a bit too long, and would not thread all the
way through the adapter (putting the nut on wouldn't really help this problem).
so i bought a new bolt (5mm shorter), and it fits perfectly (lengthwise). but with
both bolts, they were a tiny bit smaller (diameter) than the hole they went
through, so there was a bit of wiggle room. this would also cause there to be a
clicking noise when i shifted. i solved this by putting about two wraps of electrical
tape around the bolt. this makes it fit perfectly and now shifts smoothly and noise
free.
one problem with this style adapter (i believe all brands have this issue) is that it
hits the plastic around the boot. right now i have the boot totally out, but with a
very small amount of dremel work, i think i'll have enough clearance.
overall, i think the adapter is well made, feels solid, and looks good. despite the
few issues i mentioned (and fixed) i also think it works quite well (the throw is
noticeably shorter), so i am happy with my purchase.
if possible i'd go for one like this:
due to the built in spacer (which if built properly, should be the correct length bolt,
and hopefully would not have any "play" in the fit) it also appears to be angled
right where mine his the plastic around the boot, but this may or may not be
enough clearance.
i plan on taking some measurements to see how much shorter the throw actually is, but for now here's some pics of it installed:
wrench.
washer).
free.
enough clearance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.P. »</TD></TR><TR><TD CLASS="quote">Is it just my eyes, or is the only thing securing that adapter to the shift lever is one tiny set screw??? that just doesnt seem very reliable to me...
-jP</TD></TR></TABLE>
in the last pic look at the lower hole (end of a bolt sticking out with a nut on it).
that's is what normally goes through the part attached to the top hole.
this part is welded onto the shift lever.
if there were only two holes the adapter would be free to rotate.
the set screw just stops forward/backward rotation and holds the adapter firmly in place.
it's on there pretty solidly
if the set screw works itself loose i'll throw some loctite on it, but it seems to be holding fine.
as promised, i checked how much it actually shortens the throw.
here's the test setup:
yardstick referenced to the 5" line:
here's the stock configuration.
third gear (forward):
fourth gear (back):
as you can see the throw is ~2.5" in either direction.
here's with the adapter installed:
fourth gear (back):
the throw is now 1.75" - 2" in either direction.
that works out to a decrease of 0.5" to 0.75" (approx).
which is 20-30%, pretty close to the advertised 25-30% (for accords)
for $30 shipped i'm pretty happy. if i had $200 i'd get a pspec:
http://www.pspectuning.com/980...r.php
50% throw reduction, 2.5" height reduction, new boot, new **** (all of which look very well made)
does anyone know if these are available? i found the group buy thread from early 06, but they still aren't available on the site (for 98-02 accord).
but for now i'm getting a custom shift **** machined and i'll probably cut down the shift lever ~1" (and cut new threads).
fourth gear (back):
fourth gear (back):
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOP END MS »</TD></TR><TR><TD CLASS="quote">Yes PSPEC Short Shift Kits are available. $220 through PSPEC. ( or $210 from me. )
for the 98-02 accord?
not shown for ordering on your site or pspec's site.
but i don't have $200 anyways.
</TD></TR></TABLE>for the 98-02 accord?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 4107 »</TD></TR><TR><TD CLASS="quote">i reported this thread and asked that it be added to the Accord FAQ</TD></TR></TABLE>
cool, there's a link in the faq to a similar write up (for the 6th gen as well), but i'm willing to take more pics if you want to get a better view of something.
added
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xluben »</TD></TR><TR><TD CLASS="quote">cool, there's a link in the faq to a similar write up (for the 6th gen as well)...</TD></TR></TABLE>
yes, there is a link already in there but I liked how you described what you did to make the adapter work. If you do cut the plastic around the boot and it clears, please update this thread with pictures so people can see that as well.
It's worth it to have this added to the FAQ's for future reference if somebody has similar problems with a short shift adapter they've purchased.
added
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">If you do cut the plastic around the boot and it clears, please update this thread with pictures so people can see that as well.
here ya go:
it is actually the highest point on the adapter that contacts the area around the boot.
here is a picture with the adapter installed and the car in reverse:
and here it is in fifth gear:
i'd say there's just over half an inch of clearance. this is actually enough to not touch the boot. the problem comes when you shifting into reverse or fifth.
here's a picture of the car in neutral with the stick as far to the right as possible (as if shifting into reverse or fifth):
it's around a 1/4" of clearance, and this is when the adapter hits the boot. then as you shift into gear it pops the console area up.
here's a pic of the underside of the boot to show what it's hitting:
5 minutes with the dremel and it looks like this:
re-installed and it works perfectly.
i used a dremel with a reinforced cutoff wheel and went VERY slowly to make sure i didn't cut up the pleather.
i would suggest removing the pleather to do it, but don't have a stapler strong enough to reattach it.
</TD></TR></TABLE>here ya go:
well, i trimmed the shaft off today.
followed these guides:
http://www.ntpog.org/mods/fifth-****/****.shtml
http://www.filtsai.com/accord/...x.php
threaded down to the bend and trimmed off 1.5" - 2"
here it is with the **** off:
and here's it is all put together:
trimmed down to 6" high (originally around 8"):
and here's the new throw:
neutral:
thrid:
fourth:
down to around 1.5" each way (forward is actually just over 1.5"), which is down about 40% from stock
neutral:
thrid:
fourth:
