y7/y8 Mini-me... Confirm if I have all parts need for IM swap
OK, my mini-me is coming close to being finished
I have a 2000 CX with 53K miles on her
Y7 with a Y8 head on it, vtec solenoid is there
Parts laying in my apt...
97 Y8 IM (5 speed) Fuel rail and injectors and hoses are on
98 Y8 TB with MAP and TPS sensors
2-wire IACV (still need to get some bolts to attach to the IM)
Chipped P28
OBD2 > OBD1 harness
DC 4-1 header
header, IM, and TB gaskets
Still need TB cable... what all will fit?
what else should I have ready before I do this swap?
pics for clicks...
Thanks to HT Marketplace
Chipped P28
OBD2 > OBD1 harness
DC 4-1 header
pics for clicks...
well the head is already on the car, and HAS been on the car for like, 20K miles
People have been telling me to get a thinner gasket, but I dont wanna put my compression up very much. I just wanna put a little more pep in my hatchy =P
I will be doing an oil change, and replacing my oilpan gasket (cause I think it might be leaking a little) *shrug*
and more than likely the conversion harness was made for an EX model, so you are going to need to make a couple wireing changes at the ecu for the 2 wire iacv. and make sure you use the right throttle body gasket. use the one that matches the throttle body, not the intake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">A new intake manifold and throttle body gasket. You can use your stock y7 throttle cable.</TD></TR></TABLE>
If you read the first post, I listed the parts that I have... some of those parts include a new intake manifold and throttle body gasket.
And the Y7 Throttle cable, from what I hear, is extremely long, and its better to swap it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars »</TD></TR><TR><TD CLASS="quote">and more than likely the conversion harness was made for an EX model, so you are going to need to make a couple wireing changes at the ecu for the 2 wire iacv. and make sure you use the right throttle body gasket. use the one that matches the throttle body, not the intake.</TD></TR></TABLE>
I got my ECU and Harness from Phearable.net, hopefully I dont have to make many changes to it. Good thought though... I'll look into it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">also be sure to add some oil when you are done</TD></TR></TABLE>
Yeah, need that vtec to work
hes right you can use your stock throttle cable just did a y8 IM swap on my friends y7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walsh22 »</TD></TR><TR><TD CLASS="quote">make sure!! u change the head gasket or else ull get an oil leak and have to take the head off and put in the gasket and do everything again..dont want that</TD></TR></TABLE>
Yeah, I am all for doing it right the first time, hence the creation of this thread
Thanks for the suggestion, I'll have to pick up a gasket this/next week.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKidd »</TD></TR><TR><TD CLASS="quote">Good luck with the mini-me swap. Got one on my 00 cx hatch too. Its a pretty decent gain. Boost that B*tch next!!</TD></TR></TABLE>
Yeah? I have no idea what kind of power gain to expect... some people are saying 20-30whp
I know the Y7 is putting a hurtin on my performance, but it's nice when I travel back to my parents house.
I've been looking at the LSD D15 tranny off and on. It would definately help out in AutoX and the strip
My current setup only pulls a 16.5 @ 80 with a 2.3 60ft
I've been looking at the LSD D15 tranny off and on. It would definately help out in AutoX and the stripMy current setup only pulls a 16.5 @ 80 with a 2.3 60ft
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {PBA}Threat »</TD></TR><TR><TD CLASS="quote">OK, so I'm looking around for head gaskets... any good recommendations on where to buy?
What thickness should I get? </TD></TR></TABLE>
I'm not positive but I'm pretty sure what a lot of people do is buy regular Y8 gaskets and take out the middle layer.
That'll give you like .3+ on the CR.
It's a nice little bump if you already have the head off, I'd do it
- you're not going to need higher octane gas because of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
- you're not going to need higher octane gas because of it.</TD></TR></TABLE>
Sounds good
I'm just going to assume that getting the gasket from HOP is going to be pricey, anywhere I should check before I go to them?
- you're not going to need higher octane gas because of it.</TD></TR></TABLE>Sounds good
warwagon
Feb 22, 2004 03:13 PM
