b18c1 block with b18b crank and rods
Old Jan 16, 2007 | 08:25 AM
turbo18coupe's Avatar
Default b18c1 block with b18b crank and rods
I am planning on putting a b18b crank/rods combo in to my b18c1 block, any body has done this before? will it work?
Old Jan 17, 2007 | 11:53 AM
no body try this before??????????
Old Jan 17, 2007 | 03:34 PM
NJIN BUILDR's Avatar
Default Re: (turbo18coupe)
I believe your the first...lol
You may need to bend the oil squirters a little to clear the pistons etc...
Old Jan 25, 2007 | 06:41 PM
b0613's Avatar
Default Re: b18c1 block with b18b crank and rods (turbo18coupe)
yes it works. take block to machine shop, or do it yourself. got to plug up those holes. better to machine shop cuz of the threads on bolts. its alot of power in that setup. i built it 3 years ago.
Old Jan 26, 2007 | 10:51 PM
j spec's Avatar
Default Re: b18c1 block with b18b crank and rods (b0613)
check the all motor thread
Old Jan 27, 2007 | 07:37 PM
Muckman's Avatar
Moderator in Chief
Ive been running that setup for 3 years. LS rod bearings are wider than GSR/ITR rod bearings!
Old Feb 5, 2007 | 10:18 PM
clem kevin's Avatar
how does this run with vtec? does it influence it at all?
Jap_Spec_Imports
Mar 15, 2009 01:02 PM
nyceli
Mar 11, 2009 09:32 AM
rough_draft
Sep 13, 2005 09:33 PM
konidude
12
Sep 2, 2005 04:46 AM
vg7z
Jun 6, 2005 04:53 PM
