95 Si VSS same as DX or EX?
Old Jan 16, 2007 | 07:55 AM
Ahknodd's Avatar
Default 95 Si VSS same as DX or EX?
Hey,
I'm wondering if the Vehicle Speed Sensor is the same on a 95 Si as the Ex or Dx models. Please any info is helpful, thanks.
Old Jan 16, 2007 | 07:58 AM
verycleanhatch's Avatar
Default Re: 95 Si VSS same as DX or EX? (Ahknodd)
it is the same
Old Jan 16, 2007 | 08:09 AM
Ahknodd's Avatar
Default Re: 95 Si VSS same as DX or EX? (verycleanhatch)
so then the B16 VSS and the D series VSS are the same?
kaiba's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verycleanhatch &raquo;</TD></TR><TR><TD CLASS="quote">it is the same</TD></TR></TABLE>
x2
Old Jan 16, 2007 | 08:14 AM
yeah you can interchange b series and d series vss's.
Pr0ject93hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahknodd &raquo;</TD></TR><TR><TD CLASS="quote">so then the B16 VSS and the D series VSS are the same?</TD></TR></TABLE>
a 95 si doesnt have a b16. it has a 1.6 sohc vtec
Old Jan 16, 2007 | 09:07 AM
Ahknodd's Avatar
Default Re: 95 Si VSS same as DX or EX? (Pr0ject93hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0ject93hb &raquo;</TD></TR><TR><TD CLASS="quote">
a 95 si doesnt have a b16. it has a 1.6 sohc vtec</TD></TR></TABLE>
yeah you're right, that's what I had thought. Thanks for the help guys.
later, davey
Old Jan 16, 2007 | 09:32 AM
SkoundrelUSA's Avatar
cute little bastard
Are you sure?
I've seen Z6s with the same style VSS as my B16:
And I've seen some D15B8s with VSS's like this:
Or was it because it was automatic or something?
Old Jan 16, 2007 | 11:14 AM
EgSalad's Avatar
The B Series gear on the end of the VSS is "taller". Its about 1/4" taller than the single cam VSS. I cant remember if I tired to just flat out put the single cam sensor into the b series tranny, but...
I had a broken b series VSS, and had an extra single cam one. If you take the cotter pin out of the gear, it comes apart into 2 pieces. You can take your single cam gear and mate it to the top section of the b series VSS.
Old Jan 16, 2007 | 11:21 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: (EgSalad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgSalad &raquo;</TD></TR><TR><TD CLASS="quote">The B Series gear on the end of the VSS is "taller". Its about 1/4" taller than the single cam VSS. I cant remember if I tired to just flat out put the single cam sensor into the b series tranny, but...
I had a broken b series VSS, and had an extra single cam one. If you take the cotter pin out of the gear, it comes apart into 2 pieces. You can take your single cam gear and mate it to the top section of the b series VSS.</TD></TR></TABLE>
taht's probably only true for hydro bseries transmissions.
the gear on a b-series CABLE trans is exactly the same as that on a d-series manual trans.
even down to the color and teeth count.
I just had my 91 LS VSS sitting right next to the 94 ex VSS I'm using in my swap and they are identical.
I'm using it right now and the speedo works just fine.
joey funk
Nov 15, 2007 10:13 PM
b20accord
12
May 21, 2007 09:01 PM
jesus-gomez
Dec 7, 2006 12:16 PM
96LSTegra
Jul 25, 2004 07:15 AM
4door93civic
28
Nov 14, 2003 12:31 AM
