Tranny problems. or Flywheel??
Old Jan 16, 2007 | 07:00 AM
92accordh22a's Avatar
Default Tranny problems. or Flywheel??
okay so im driving and all of a sudden there is a whole lot of pressure in my clutch pedal, and it won't let me shift into gear , when i turn the car off and put it in gear, w/clutch also in and when i crank her over the clutch is still enguaged and the car lunges forward , there is a new T/O bearing, Presure Plate, Clutch Disc, would a bad flywheel or flywheel bearing cause this ?? i am already in the market for another H22 Trans i have never had this happen. when the car is cold the clutch works fine but when it warms up the problem occurs DO YOU GUYS THINK ITS CLUTCH / FLYWHEEL / TRANSMISSION ????? *PLEASE NO JOKERS* Thank you.
Old Jan 16, 2007 | 07:10 AM
Ross 2.0's Avatar
In a Junkyard near you.
sure you don't have a weak leg?
So you can't push it in or there is a lot of pressure? Sounds like something is binding up in the parts you just put in.
Old Jan 16, 2007 | 07:16 AM
Default Re: (Ross 4107)
lol im sure brother, My leg is fine.
I was thinking that (binding up) but it just does not make sence to me , that when its cold its fine but when its warmed up its F#CT , the presure thing went away there is no presure in the pedal anymore. Don't you love These Problems?? i Also think it might be the clutch maybe theres a defect so i guess theres only one thing to do , RE-DO Everything! Thanks For your time Bro. Its Smoke TIME 420!!!
Old Jan 16, 2007 | 07:21 AM
02 accord's Avatar
Default Re: (92accordh22a)
Binding up makes sense. It's fine when it's cold, but when everything warms up, parts expand, causing them to bind.
Old Jan 16, 2007 | 09:49 AM
Default Re: (02 accord)
well i guess best thing to do is pull it apart, thanx guys
Old Jan 16, 2007 | 12:49 PM
Also when i was driving it , it was fine but then i started to feel a diff in the pedal so i pumped it and then it F#cked up and it wiould not go into gear...Had to tow her home.
Old Jan 16, 2007 | 12:54 PM
Ross 2.0's Avatar
sounds like something isn't letting the clutch fully engage and it's not fully releasing the clutch from the flywheel when you push it in. I would definitely pull the transmission back out and see what's up.
You can try to bleed the clutch but I don't think that's it.
Old Jan 16, 2007 | 01:06 PM
I've been doing my research trying to find out which transmission i should use ? m2b4 or t2w4 , since im pulling it out i might as well replace it with a lsd trans.
Thank you!
Old Jan 17, 2007 | 07:45 AM
what do you think ??? Check fluid , add if needed and beed the system. also if the slave cyl is bad the clutch wont work at all correct?
EDWINV00SI
24
Oct 13, 2011 06:08 PM
nitewolf
Nov 8, 2007 12:03 PM
96b18c
Mar 2, 2006 01:54 PM
99simoder
Nov 20, 2005 08:18 PM
streakz
Nov 16, 2003 06:57 PM
