Jdm shift boots...and getting shift knob back to normal...?
this one is mine
how do i get it to sit like this one (pointing down)
and is their a certain way to screw the shift **** back on, to make it straight? do i have to tighten the bolt below the shift **** alot more? its all the way down, i can get it with my hands, havent pulled tools on it yet...
[Modified by Jordo, 3:08 PM 5/15/2002]
j00 want your b00t like mine?
Give it some time to flex and get some heat on it... mine looked like your at first... now you see what it looks like..
Willis
Willis
you've gotta tighten the nut against the ****. the nut won't go all the way down and let you line the **** up straight.
no no no.. I IMed him...
The nut that is under the **** is holding up the boot in his picture. He needs to take the boot back off and take the nut off. Then slide the boot on. then put the nut on and the adjust accordingly
Or at least thats how it looks to me...
so i shoudl tighten the **** or the bolt?
what doi tigthen bolt with
Use a adjustable wrench, but wrap a towel around the nut to prevent maring/scratching it.
if i remember correctly... the nut is size 12...
i wrapped the nut w/ electrical tape before adjusting it.... it worked good..
