b18a with a injector leak!
Old Jan 15, 2007 | 07:34 PM
harmonator84's Avatar
Default b18a with a injector leak!
Aight I have searched and I found where ppl are saying its there oring is bad but IDK which one is causing my leak.
According to this picture there are two orings #2 and #16. I thought mine was #2 but after reading other ppls post I think the leaks come from #16.
I know that 90% of HT has ran across this problem and I was just wondering where this leak usually comes from. I am loosing alot of fuel from around my injectors and I dont know which oring to replace.
Old Jan 15, 2007 | 07:35 PM
Default Re: b18a with a injector leak! (harmonator84)
oops I didnt mean to post this in the civic/delsol section.
Could mods please delete this post. Thanks.
Old Jan 15, 2007 | 07:36 PM
Zeusfire69's Avatar
I would say number 16, there is high pressure behind it, the other one, number 2, just seals the injector to the manifold so it doesn't have any pressure on it.
EJgsr's Avatar
it could be ether have a friend prime the system and see what one its coming from.
Old Jan 15, 2007 | 07:40 PM
Default Re: b18a with a injector leak! (USDMej1)
Thanks alot guys.
THis is actually on a crx thats why I just wanted the mods to kill the post.
THanks for the replys though. I am leaning more toward replacing both of them now.
Old Jan 15, 2007 | 11:00 PM
slickdowneg's Avatar
could be ghetto and put silicone around number 2
Old Jan 17, 2007 | 10:32 AM
Default Re: b18a with a injector leak! (slickdowneg)
Ok. I have my injectors out and they have what looks like carbon build up on them"soot"...just wondering what I can use to clean my injectors while they are out. Should I dip them in some injection cleaner or something?
Old Jan 17, 2007 | 10:34 AM
Archidictus's Avatar
Unceasing Measure
Use "brake clean" to clean the injectors and replace all of the O-rings. If it's not going to break the bank - and I hope it wouldn't - it's a good precaution. If one is going bad, they'll all follow suit shortly.
Old Jan 17, 2007 | 10:36 AM
Default Re: b18a with a injector leak! (Archidictus)
Oh I have already ordered 4 new seal kits. Changing all 12 rings.
Old Jan 17, 2007 | 10:37 AM
ExCon's Avatar
^ I agree, I say replace the O-Ring!
Gideon Sol
Mar 30, 2013 06:31 AM
harmonator84
11
Jan 17, 2007 10:50 AM
