finishing motor swap wiring harness ??
Old Jan 15, 2007 | 06:27 PM
kbouchard1092's Avatar
Default finishing motor swap wiring harness ??
i am finishing puting in my b16a sir2 i have a 99 civic ex. im pretty sure i can use my factory d16y8 harness however a bunch of it was hacked up from the prior owner so i just want to buy a new harness i ive invested alot into it and dont want a wiring harness giving me headaches down the road so im replacing it with an ucut one. my question is should i buy another y8 harness or change to an obd1 engine harness because the engines obd1.so i dont got to buy injector clips and the obd2-obd1 connector cause im running hondata with an obd1 p28. just wondering whats my best option?
Old Jan 15, 2007 | 06:28 PM
Eran's Avatar
HT White Ops
If you're running an OBD1 ecu and an OBD1 motor, you might as well use an OBD1 harness.
*2 Cents*
Old Jan 15, 2007 | 06:35 PM
Default Re: (Eran)
true. .just wasnt sure how exactly it would fit or if anything would have to lengthened does the obd1 harness have a electrical VSS connector?
Old Jan 15, 2007 | 06:36 PM
Eran's Avatar
HT White Ops
Default Re: (kbouchard1092)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kbouchard1092 &raquo;</TD></TR><TR><TD CLASS="quote">true. .just wasnt sure how exactly it would fit or if anything would have to lengthened does the obd1 harness have a electrical VSS connector?</TD></TR></TABLE>
I can't remember off the top of my head if VSS work cross-OBD.
Old Jan 15, 2007 | 06:41 PM
Default Re: (Eran)
well i got an 99 si tranny i have the type r final drive and lsd in it but im reusing the 99 si VSS conector thats what my gauges need to work is and electrica i know some pre obd2 arnt electriacal so if i went obd1 harness that would need an eclectrcal connector
purple98ek
30
Nov 8, 2007 08:53 AM
1BADEGDC2
May 12, 2007 07:43 PM
94vtirozguy
Aug 13, 2006 01:00 AM
91hatch_on17's
Sep 2, 2003 08:27 PM
