Will ek brakes fit an eg?
I have a 95 eg(dx) coupe and need some pads and rotors. Anyways My buddy crashed his 97 civic(ex). I wanted to know if i can use the entire front suspension minus the struts and springs.
So can i use the upper ball joint, spindles, calipers, and lower control arms and run the front sway bar? I wanted to use the front brakes cause i heard that the Si/EX brakes are bigger than the stock ones that my car came with. And the lower control arm cause obviously the sway bar. So will these fit?
you can use the EK spindles/knuckles with caliper and rotors without any issues.
Unfortuantly upper control arms are different, lower LCAs are also NOT a bolt on, unless you feel like swaping a complete crossmember along with steering rack and rear mount to EK spec.
I`ll pass on that swap, i didn`t think it would work. So as far as the brakes are they biggier or just go with the stock pads and rotors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_civic_Si »</TD></TR><TR><TD CLASS="quote">I`ll pass on that swap, i didn`t think it would work. So as far as the brakes are they biggier or just go with the stock pads and rotors?</TD></TR></TABLE>
EX rotors = 10.25"
DX rotors = 9.5"
yes they are bigger
EX rotors = 10.25"
DX rotors = 9.5"
yes they are bigger
Orientalbigboi
Sep 8, 2007 11:22 AM
endlesswinterco
12
Nov 7, 2003 05:43 AM
