Problem...
Old Jan 15, 2007 | 04:22 PM
DohctorVtec's Avatar
Default Problem...
Ok I got a problem here I would like to look into and fix. Whenever I get on my car from a deadstop I go through 1st and 2nd gear vtec fine, but when I hit 3rd at around 7k RPM's my CEL pops on and vtec noticeably gets weaker and the car noticeably goes slower. I am not throwing any codes so I have no clue what is going on please help...
Old Jan 15, 2007 | 04:26 PM
bart2546's Avatar
Default Re: Problem... (DoctorVtec)
Do you have enough oil in the car? If you don't and you're oil pressure is going down at that point with that much more load on the car, it would cause the vtec to kick off and possibly a check engine light, although a CEL will cause vtec not to work in itself. If you're getting one, there's probably a code stored in the engine, you don't need to have a solid CEL for it to keep a code because just as your post states, it happens at a certain point/time frame...so I'd run a check on that.
Old Jan 16, 2007 | 05:43 AM
Default Re: Problem... (bart2546)
Yeah I have enough oil for sure. Oil is changed on the dot every 3000 with Mobil 1 Synthetic. Bump for any info!
Killspeed93
Sep 21, 2011 08:12 AM
JDMtegg19
10
Jul 10, 2009 10:08 AM
hotdoggies
Apr 11, 2005 04:25 AM
Worangejuice
Nov 15, 2003 06:36 PM
311
Oct 23, 2002 08:20 AM
