car hesitating to accelerate
Old May 15, 2002 | 10:52 AM
LB CRX's Avatar
Default car hesitating to accelerate
this happens mostly when im on the freeway where i try to accelerate and the car hesitates and slows down. i have to push on the throttle a couple of times before it works properly. can this be my timimg? fuel? or tps?
tia
Old May 15, 2002 | 01:46 PM
satan_srv's Avatar
Default Re: car hesitating to accelerate (LB CRX)
What engine, what fuel?
Old May 15, 2002 | 08:51 PM
LB CRX's Avatar
Default Re: car hesitating to accelerate (satan_srv)
b16..pressure is at 40 psi. i never figured out why im still getting the code 1 and 2. could that cause it?
Old May 16, 2002 | 04:55 AM
EE_Chris's Avatar
In the future, if you've got the CEL on, it would be nice to know that on your first post, not close to a 1/2 a day later.
However, those 2 codes are for the O2 sensors, A & B, which are both primary O2's. As far as I know, the old B16's had 2 in the exhaust manifold (someone wanna verify that), one to monitor 2 cylinders each.
EDIT: Please also note the links in my sig...one of them is for ECU codes.
[Modified by EE_Chris, 1:56 PM 5/16/2002]
Old May 16, 2002 | 07:33 AM
Chiovnidca's Avatar
What year and model do you have? Are you sure it's not a code 12?
Old May 16, 2002 | 05:57 PM
LB CRX's Avatar
Default Re: car hesitating to accelerate (Chiovnidca)
sh*t...i think it is a code 12. the EGR? how do i go about fixing that?
Old May 16, 2002 | 07:51 PM
BreakStuff's Avatar
New User
Default Re: car hesitating to accelerate (EE_Chris)
Old May 16, 2002 | 09:35 PM
LB CRX's Avatar
Default nope
it is a code 1 and 2. the reason i didnt say anything about the cell is cuz i had an earlier post about the code 1 and 2 but i didnt get any response....so i figured i might approach it a different way.
i have my wires hooked up to the type r header sensor but im still getting the codes even after i reset the ecu. i thought this might be causing the hesitation in my acceleration... but i was hoping somebody might say different.
DReckson
May 23, 2014 07:01 AM
roc0487
Dec 26, 2008 05:29 PM
1.8Tities
Sep 9, 2003 02:11 PM
