BPi velocity stack?
Old Jan 15, 2007 | 09:43 AM
rcar97's Avatar
Default BPi velocity stack?
Is anyone running one of these with an AEM CAI? If so, what filter did you use and did everything fit inside the fenderwell easily?
What do you think, worth it or not?
Thanks
Old Jan 15, 2007 | 11:07 AM
neo_'s Avatar
Default Re: BPi velocity stack? (rcar97)
http://www.itrca.com/forums/vi...light=
Old Jan 15, 2007 | 11:58 AM
doood's Avatar
been there done that
Default Re: BPi velocity stack? (neo_)
http://bpinitiatives.com/products.html has the recommended filter pn listed
Old Jan 15, 2007 | 07:04 PM
type B16's Avatar
any dynos with a cai bpi stack?
Old Jan 15, 2007 | 07:15 PM
neo_'s Avatar
Default Re: (type B16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 &raquo;</TD></TR><TR><TD CLASS="quote">any dynos with a cai bpi stack?</TD></TR></TABLE>
Do you rather mean before and after dyno runs?
BTW, CAIs don't do as well on a dyno as in a real world operation.
Old Jan 15, 2007 | 07:31 PM
type B16's Avatar
i actually want to see a full cai with the stack vs. a cut cai sri with the stack if its worth the difference in power
Old Jan 17, 2007 | 10:43 AM
itr1244's Avatar
Default Re: (Boostless)
i tired hooking up the stack at the end of a CAI and a short ram
short ram sounds and feels alot better than one with cai
Old Jan 17, 2007 | 11:33 AM
DontBlink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostless &raquo;</TD></TR><TR><TD CLASS="quote">Anyone else? Any dyno testing? </TD></TR></TABLE>
heres one on my wifes rsx type s.
green line is the aem v2 short ram
red line is an 3" short ram intake with the velocity stack
i got a bunch more of other motors i just gotta get time to dig through them all.
this is the BPI stack with the K&N filter and silicone i got for her car.
Old Jan 17, 2007 | 12:29 PM
type B16's Avatar
if you look at the af graph, it looks like the sri has better tuning compared to the v2
Old Jan 17, 2007 | 12:33 PM
DontBlink's Avatar
found it. aem cold air(blue line) ve aem cold air with a BPI stack on the end(red line)
Modified by DontBlink at 4:47 PM 1/17/2007
Old Jan 17, 2007 | 12:34 PM
type B16's Avatar
Default Re: (DontBlink)
now we need a bpi cai vs bpi sri
Old Jan 17, 2007 | 12:51 PM
DontBlink's Avatar
now we need a bpi cai vs bpi sri</TD></TR></TABLE>
bpi cai(blue line)
bpi sri(red line)
Old Jan 17, 2007 | 01:04 PM
neo_'s Avatar
You can not simulate the effect of a CAI on a dyno. When the car is actually moving, you get colder air sucked up since it isn't coming from your engine bay like an SRI. On a dyno the car is not moving and just suctions up radiant air.
Old Jan 17, 2007 | 01:17 PM
type B16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DontBlink &raquo;</TD></TR><TR><TD CLASS="quote">bpi cai(blue line)
bpi sri(red line)
yep, this is exactly what ive been dieing to see thanks
Old Jan 18, 2007 | 04:37 AM
rcar97's Avatar
Thanks for the info guys I still think that cai will make more power, dyno doesn't tell it all. Either way I'm going to pick one up for sure now!
Old Jan 18, 2007 | 07:56 AM
TigerIntegra's Avatar
Default Re: (rcar97)
just recieved mine today i should have a dyno graph up this week
Old Jan 18, 2007 | 08:45 AM
itr1244's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostless &raquo;</TD></TR><TR><TD CLASS="quote">Wow! That's a huge difference. The V2 is already supposed to be the best intake on the market. Have you tested this on a b series? I might have to cut my cai so I can try it as a SRI too. Anyone else?</TD></TR></TABLE>
says who ?
Old Jan 18, 2007 | 08:48 AM
itr1244's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcar97 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info guys I still think that cai will make more power, dyno doesn't tell it all. Either way I'm going to pick one up for sure now!</TD></TR></TABLE>
if you really believe that the CAI will make more power why dont you get cai instead of v stack?
and why waste money on something that's not gonna work for you
i'm not saying that v'stack is ****. .. just in your case scenario
Old Jan 18, 2007 | 09:52 AM
neo_'s Avatar
Default Re: (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">if you really believe that the CAI will make more power why dont you get cai instead of v stack?
You are comparting apples to oranges, you can run both at the same time like I do.
Old Jan 18, 2007 | 10:45 AM
itr1244's Avatar
Default Re: (neo_)
all i gotta say the length of the pipe will make differance in powerband . specially with the v-stack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">
You are comparting apples to oranges, you can run both at the same time like I do. </TD></TR></TABLE>
i defently tired it.. and didn't like it at all compared to my short ram + v stack setup.
cai with v stack felt like i lost alot of throttle response and short ram sounds much better
i think the longer the pipe the higher the peak power band
shorter the pipe the lower rpm power band
Modified by itr1244 at 3:16 PM 1/18/2007
Old Jan 18, 2007 | 08:13 PM
rcar97's Avatar
i'm not saying that v'stack is ****. .. just in your case scenario </TD></TR></TABLE>
I already have the AEM CAI, just looking for a cheap way to make some more HP with it.
Old Jan 22, 2007 | 06:19 AM
Renegade's Avatar
maybe I don't fully understand this whole Air Fuel ratio, but i have noticed in the past wiht my tunes that if you run leaner you tend to make alittle more power. that is what is happening here isn't it? i wonder how much power there once it is tuned. Of course, I do not know what AF ratio an RSX likes but if everyone else has their AF graphs it would be nice to post them as well.
RSXs motors always respond better to mods than B series motors.
Not bashing on anyone, just trying to understand it a little better
Old Jan 24, 2007 | 11:42 PM
Downey's Avatar
Default Re: (Renegade)
i agree about the air/fuel ratio. the change from 13.8 to 14.16 maybe not seem like much but it is.
from our dyno experience without changing anything on the car and leaning out the fuel curve will increase power.
14.16 is a little lean for my liking.
one of our racecars made close to 169whp at 13.8:1 and only 164 @ 13.4:1. we left it at 13.4:1 because we use a ram air headlight with shortram which will lean it out on the track anyway.
Old Jan 25, 2007 | 04:03 AM
CXtypeR's Avatar
Default Re: (Downey)
how lean can you go at wot without blowing anything up?
Old Jan 25, 2007 | 02:55 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: (CXtypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXtypeR &raquo;</TD></TR><TR><TD CLASS="quote">how lean can you go at wot without blowing anything up?</TD></TR></TABLE>
It depends on a lot of factors. Fuel being used, type of internals, load, etc.
I had mine go off the chart lean (past 18:1) on one pass and it still held together. BTW, shout out to the dyno operator that day who was watching the AF's and didn't shut it down. His words after the pass "man, I don't know how it didn't blow up on that one". Thanks.
