Got some pics of my new LSturbo setup
Old May 15, 2002 | 09:31 AM
MIKES's Avatar
Default Got some pics of my new LSturbo setup
What started out simple turned as complex as a Rubix cube. After posting my parts on here and having some of the turbo gurus critique my setup. I have changed lots. I even started getting **** with my shitbox and resprayed my engine compartment, wheelwells, trunk, and relocated my battery to the trunk. I am waiting for my engine pieces to come back that I sent out for polishing, then I can start to put Humpty Dumpty back together again. Right now I have parts everywhere, I hope **** doesn't get hacktic when its time to go back in. Well enough babbling already, here is my link http://community.webshots.com/user/ricketts100 Tell me what you guys think, and don't worry. I have some thickass skin so let a brother hear it. My mods are:
>-B18A non vtec motor
>-My JG non vtec fully ported head
>-1001 JG cams
>-JG match ported intake manifold (stock)
>-JG throttlebody
>-Eagle rods & J&E pistons (motor has 9.65 to 1 comp)
>-TypeR oil pump
>-STR blockguard
>-Reactive aluminum crank pulley
>-AEM cam gears
>-T3 T4OE turbo (off my GN)
>-Drag manifold
>-2 1/2" downpipe
>-2 1/4 Exhaust to a Dyno Max muffler (straight pipe no cat)
>-power steering belt removed
>-Taylor 8mm wires
>-NGK spark plugs (BCPR7ES-11) gapped @ 32
>-all oil lines, etc
>-Richard Lee Wastegate (uses the same flange as Deltagate buts supports up to 800whp)
>-Grand National Intercooler modified with 2 " inlet and outlet (Front mount, supports up to 400whp)
>-2 1/4 Chrome intercooler piping
>-HKS blowoff valve
>-550cc injectors
>-B16A tranny with LS 5th gear (but still have 2 LS trannies if traction becomes a problem)
>-stock flywheel lightened to 13 pounds
>-Clutch Masters Stage3 clutch & pressure plate
>-Buick Grand National fuel pump & inline fuel filter (the stock one was pitched)
>-B&M adjustable fuel pressure reg
>Zydne Gold ecu
What can I expect for whp numbers? and what don't you like about this setup. Flame if you have to, thats cool as long as you tell me why. I want this to be right and do it once, so anything you can tell me to help out would be greatly appreciated.
Old May 15, 2002 | 09:42 AM
AGen2integra's Avatar
Default Re: Got some pics of my new LSturbo setup (MIKES)
very nice mike ......good luck getting everything together.. by the way thats exactly what my car look like right now!
Old May 15, 2002 | 09:55 AM
DIRep972's Avatar
Smarter than you
looks great. only thing I would change is get a larger exhaust..
btw, thats a clean 2nd gen u got there, but the type R stickers gotta go.
Old May 15, 2002 | 10:00 AM
Doodoo's Avatar
Are you using stock sleeves? If not I would re-sleeve it even though it cost bucks. I regret getting a block guard. Not because it has failed on me, because it hasn't, but because I want more boost! I always worry about the sleeves not holding. Thats all.
[Modified by Doodoo, 1:03 PM 5/15/2002]
Old May 15, 2002 | 10:06 AM
stick's Avatar
-bigger exhaust
-use stock OE cams
-LS tranny
-LSD (kaaz or quaife)
-lots of tuning
looks good tho
Old May 15, 2002 | 11:09 AM
MIKES's Avatar
Default Re: Got some pics of my new LSturbo setup (stick)
Thanks guys. I would like a sleeve the block but I just had my first born and my wife is off for the year so my cash flow situation isn't saying alot. Hopefully I can do that over the winter along with a LSD. What do you think this setup will give me (whp)?
Old May 15, 2002 | 11:26 AM
intekragsr's Avatar
looks good, but damn direp, nice ***(avatar)
Old May 15, 2002 | 08:30 PM
DA666's Avatar
Default Re: Got some pics of my new LSturbo setup (intekragsr)
sweet 2nd gen!!!! show some pics of the setup in the car.....i wanna see how it looks....
Old May 15, 2002 | 08:33 PM
DA666's Avatar
Default Re: Got some pics of my new LSturbo setup (T3T4DA6)
tough to say whp.....id say alot....over 280 whp at least with the pistons and rods.
and the zydne....alot of whp whhen tuned properly atleast breaking 13's intto 12's wth traction
Old May 15, 2002 | 10:24 PM
Project_Integra's Avatar
New User
Another boosted G2. You guys are makin me sick!!
I need more money so I can finish my setup!
Good luck!
wfocrx
27
Sep 7, 2015 08:53 AM
Spankedrican92
28
Apr 14, 2013 07:28 PM
sc34dx
Midwest
Apr 25, 2011 01:27 PM
sc34dx
32
Apr 19, 2011 01:34 PM
GOTXQSS
Feb 10, 2005 11:07 PM
