Need heat help plz!!!!!!!!!!!!!!!!!
Old Jan 14, 2007 | 08:35 PM
SIBuddy's Avatar
Default Need heat help plz!!!!!!!!!!!!!!!!!
i blew up my motor(h23) back in May and i drove it on no coolant home from the drag strip and it was overheating bad and i turned on the head and it worked but it went out. When i got home i pulled out the h23 and put the h22 in and the heat still doesnt werk i replaced the thermostat and the heater valve and still nothing plz help also the car is a 1995 Prelude SI. thank you.
Old Jan 14, 2007 | 08:38 PM
Hawkze_2.3's Avatar
Default Re: Need heat help plz!!!!!!!!!!!!!!!!! (SIBuddy)
Does the blower work?
The heater is pretty simple...either the coolant is not flowing to the heater core or the blower is not blowing the hot air into the cabin.
Old Jan 14, 2007 | 09:19 PM
turbociv910's Avatar
Default Re: Need heat help plz!!!!!!!!!!!!!!!!! (Hawkze_2.3)
check ur hoses pal.. and ur coolant level
Old Jan 15, 2007 | 06:32 AM
1GPlusSH's Avatar
Default Re: Need heat help plz!!!!!!!!!!!!!!!!! (turbociv910)
And check the connection to the valve that allows the coolant to flow to your heater core. I wish I knew what it was called. It's the valve that you control by adjusting your temperature.
Old Jan 15, 2007 | 03:30 PM
SIBuddy's Avatar
the blower motor blows air but it is cold air and my coolant temp is norm and i replaced the heater valve (which is the valve that connects to the heater core to the cylinder head) i think i jux need a heater core.
Old Jan 15, 2007 | 03:39 PM
Hawkze_2.3's Avatar
Default Re: (SIBuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIBuddy &raquo;</TD></TR><TR><TD CLASS="quote"> i think i jux need a heater core.</TD></TR></TABLE>
Have fun with that...it's a bitch I honestly would try everything you can before you take out the heater core. I couldn't see it going bad very easily unless it was clogged up or had a hole in it or something (then it would leak into the car).
You sure the cable from your climate control is properly opening up the valve?
Old Jan 19, 2007 | 09:38 AM
PrettyLude's Avatar
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Have fun with that...it's a bitch I honestly would try everything you can before you take out the heater core. I couldn't see it going bad very easily unless it was clogged up or had a hole in it or something (then it would leak into the car).
You sure the cable from your climate control is properly opening up the valve?</TD></TR></TABLE>
Old Jan 19, 2007 | 11:48 AM
BB2H22's Avatar
What do you do if the blower doesnt work?
Old Jan 19, 2007 | 01:03 PM
Driveshaft's Avatar
Default Re: (BB2H22)
Check your blower motor resistor.
Old Feb 5, 2007 | 05:35 AM
mrmckie's Avatar
Where's the heater valve located and how do i open it, to let the hot air in the cabin??
My cable seems to be rusted so it's stuck on cold and i'm freezing my *** off.
Can someone provide some pics??
DEDO
Jan 22, 2013 06:20 AM
mooseswizzle
Mar 31, 2011 05:22 PM
sde780
15
Sep 29, 2009 06:57 PM
Nicaraguense13
Jan 21, 2008 04:20 PM
R249
Jan 24, 2003 11:10 AM
