p28 max rpm mapping
Old Jan 14, 2007 | 07:05 PM
100nx's Avatar
Default p28 max rpm mapping
Srry, Im new to the forum. I tried searching, but I couldnt find my exact answer. What is the max RPMs on a P28 that it maps up to? Also, can the map be expanded with software like crome? TIA
Old Jan 14, 2007 | 07:49 PM
Richard...'s Avatar
Default Re: p28 max rpm mapping (100nx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 100nx &raquo;</TD></TR><TR><TD CLASS="quote">Srry, Im new to the forum. I tried searching, but I couldnt find my exact answer. What is the max RPMs on a P28 that it maps up to? Also, can the map be expanded with software like crome? TIA</TD></TR></TABLE>
how hi are you wanting to rev? and whats the point if your not making power up there just curious?
Old Jan 14, 2007 | 09:04 PM
100nx's Avatar
Default Re: p28 max rpm mapping (richard7968)
I want to know the boundaries of this ECU. I want it to have the ability to map up to 10k. The springs I want top out at 9600 and the cams make peak power in the high 8k range.
I actually want to do this build in couple years, so it wont be anytime too soon. I just want to get all my research out of the way. I actually have a Nissan with an SR20. But the tuning solutions for this motor are not as good as Honda stuff. I actually was looking into running a P28 w/ crome on my motor.
Now, I know I will prolly get flamed, and many people have an opinion on why I shouldnt do this, or have questions of why I want to do this. If you want to comment, plz gimme my answer first, and then I would love to hear opinions on how I can go about this build better.
TBH, Honda motors have much more research and technology when it comes to running ITBs. Most nissans run a turbo set-up. I want to be different. So I will be on this forum a lot researching ITBs and theory/setups. What ive found so far, is a P28 running crome is excellent software for ITBs.
Anyway, Im rambling. Thanks for any answers/comments.
Old Jan 14, 2007 | 11:24 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 100nx &raquo;</TD></TR><TR><TD CLASS="quote">I want to know the boundaries of this ECU. I want it to have the ability to map up to 10k. The springs I want top out at 9600 and the cams make peak power in the high 8k range.
Anyway, Im rambling. Thanks for any answers/comments.</TD></TR></TABLE>
Ok i will get into my opinions about your setup later but as for answers to your questions here goes
http://www.hondata.com/manuals....html
the above website is basically the manual for &lt;crome&gt; if you read that page it will give you an outline of whats going on and answer some of your questions
screen shots of &lt;crome&gt;
http://www.tunewithcrome.com/imgs/ss_pro3.jpg
http://www.tunewithcrome.com/imgs/ss_pro1.jpg
http://www.tunewithcrome.com/imgs/ss_pro2.jpg
in answer to how high you can go with &lt;crome&gt; is 11,000RPM
proof right here
http://www.tunewithcrome.com/b....html
hope this helps you get started!
as for your setup and goals thats another thing!
Old Jan 15, 2007 | 05:20 AM
mmuller's Avatar
Mad Scientist
with rev tools you can reach 11000 rpm maps
Old Jan 15, 2007 | 02:50 PM
100nx's Avatar
I know this is an interesting post and a setup that you prolly have many opinions about. I did d/l crome before posting this just to get an idea of the program compared to others I have used.
I have been told the sensors used in the applications are similar to each other in the values that will be received from voltages. Also, crome will help me dial it in it seems. The biggest thing I will have to look into is the ignition.
Like I said, it will be a long time before I get a chance to do my set-up. But I want to be fully ready with all the information I need before I dive in, and ironically, a Honda ECU and crome seem to be a good platform for what I want. I would definetaly be open to hearing about concerns and open for discussions.
EJgsr
Feb 14, 2007 03:30 PM
cbmprelude
23
Jun 11, 2006 08:01 PM
Topdawgg
Aug 4, 2005 03:15 PM
dominate9
Nov 17, 2003 08:30 AM
