VictorX manifold and stock fpr
i got the victorx manifold for my gsr but the fpr return line doesnt with the straight fitting on regulator bc of being to close to the plenum. What does everyone run?
What i did was take the fpr off and dried it up really good. Then i put it on a vice and stuck a screwdriver in the return line, heated it up and then bent it to where i liked it and it worked just fine. Another thing you could do if you dont want to do that is use a Y8/Y7 FPR since they have the angle return line.
