automatic to manual swap
Old Jan 14, 2007 | 04:52 PM
bmxmarine's Avatar
Default automatic to manual swap
I'm looking to swap out the automatic.... I know how hard it is to do this on an EG but how hard is it to do on an older Civic? Are the parts readily available, or should I just say the hell with it and put it in LS motor with automatic in there?
Old Jan 14, 2007 | 04:59 PM
wfocrx's Avatar
are you talking an auto-to-manual d-to-d swap or d-to-b? I did an automatic d15b2-to-d16z6 swap using a 91' si tranny. Anyways, if staying d-series you will need a manual rear mount (~$20), shift linkage (~$50), clutch cable (~$50), pedal assembly ($50)
Old Jan 14, 2007 | 05:09 PM
janz3n's Avatar
Default Re: (wfocrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx &raquo;</TD></TR><TR><TD CLASS="quote">are you talking an auto-to-manual d-to-d swap or d-to-b? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmxmarine &raquo;</TD></TR><TR><TD CLASS="quote">or should I just say the hell with it and put it in LS motor with automatic in there?</TD></TR></TABLE>
im guessing hes putting a B in it lol.. and just search this.. im sure theres tons of stuff on here about it since it gets asked alot.
i just came up with a brilliant plan.. they should make a sticky about how to use the search button in bold letters.. that would actually help alot of people.. and im not being sarcastic at all.
Old Jan 14, 2007 | 05:24 PM
bmxmarine's Avatar
I can get the parts that how hard is it to actually do the swap itself? And I will be keeping that the series motor in it most likely I'll be changing it out to a zc motor. Or I might just turbocharge the stock setup, but I'm looking at a nice civic that has an automatic transmission, and the guys wanting to trade me for my s10 but I don't really like automatics at all. So I was thinking about changing it to a manual. Just try to get an idea of how hard the swap is going to be.
Old Jan 14, 2007 | 05:31 PM
bmxmarine's Avatar
Default Re: (bmxmarine)
I did find some information on the b series swap but I did not find any for the d-series and in 88 generation Civic hatch. Almost everything else I found was for the newer hatchback but I already know how to do that swap.the biggest question I had was regarding the cable transmission, and how hard that was. Most of the rest of the parts I can get very easy. I know a guy who has a civic he's parting out just down the road
Old Jan 14, 2007 | 07:58 PM
gibsanez's Avatar
Whats the qeustion you have specifically about the transmission? Other than the different mounts, and your basic clutch, flywheel, etc, there's not a whole lot more, other than the reverse light wiring and the wiring for the neutral safety.
I used to have links to them, i'll see what i can find, cross your fingers
I can say with confidence, the pedal swap is ok, but im glad i got it out of the way first.
edit - If you don't have it on the list, 5 speed axles.
Old Feb 18, 2007 | 09:52 PM
Jonknee's Avatar
Default Re: (gibsanez)
u dont need 5spd axles
Old Feb 19, 2007 | 04:33 AM
rbwdriven's Avatar
and the wierd thing is that I have all that sitting at the house for somebody.
Only thing I dont have is the tranny.
I have the whole swap configuration at the house.
Old Mar 5, 2007 | 11:46 AM
snsamotors's Avatar
i got a eg auto and a ek manuel...problems. can i take everything from the ek and put it in my eg to make it manuel? how hard would that be?? email=sns_boost@tmail.com i need ya help.
JDMish
12
Feb 10, 2007 10:52 PM
srg
Aug 16, 2006 10:37 AM
Jlamar757
May 25, 2006 03:16 PM
ssung7
Mar 31, 2006 07:13 PM
DieMaster
13
Aug 31, 2004 10:45 AM
