Help! I can't get the crank bolt off.
Old Jan 14, 2007 | 12:44 PM
Teg_93's Avatar
Default Help! I can't get the crank bolt off.
I am in the process of changing my timing belt and I absolutely can not get the crank bolt off. I bought the tool to hold the pulley, I tried an impact wrench, I've tried to heat the bolt. Any suggestions would be greatly appreciated.
Old Jan 14, 2007 | 12:54 PM
RTW DC2R's Avatar
screw driver through the flywheel.
Old Jan 14, 2007 | 01:05 PM
andyt's Avatar
Default Re: Help! I can't get the crank bolt off. (Teg_93)
You need leverage.
I couldn't get it off with an impact either, even at ~140 psi.
The jack handle on the end of a ratchet did it though.
Old Jan 14, 2007 | 09:42 PM
4F_RiverOtter's Avatar
Default Re: Help! I can't get the crank bolt off. (andyt)
What kind of impact gun are you using? Did you try putting the gun on beast mode? Use a 3/4 inch drive air gun, it shouldn't be a problem.
Old Jan 14, 2007 | 09:53 PM
itralex's Avatar
Default Re: Help! I can't get the crank bolt off. (RiverOtter)
If you bought the crank pulley holder tool from honda then it should be easy to get it off
find your 19mm socket, 1/2" drive extension and your 1/2" rachet and a breaker bar you can slip onto the rachet
if you have a hydralic jack, then grab the jack bar off of that and use it as a breaker bar and have the crank pulley holder tool wedged ontp the front vibration mount. once you got that set up just reef on the breaker bar
Old Jan 15, 2007 | 04:40 AM
John Z's Avatar
i had a problem using an impact the damn bolt wouldnt come off... so i got this weird tool jobbie that fits into the crank pully and i put it against the LCA then i put the 19mm on and used a breaker bar.. it was a pain but it came lose.. i dont have a picture of the tool but it fits into the crank pully and u put a breaker bar on it
Old Jan 15, 2007 | 06:35 AM
Tweakmeister's Avatar
Default Re: (Yaz)
coat liberally with PB Blaster if you haven't already.
Might be a dumb question, but are you going in the right direction?
Old Jan 15, 2007 | 06:54 AM
gritsak's Avatar
Default Re: (Tweakmeister)
if you have a good impact it should come off without much problem. Turn up the air pressure and just let it hit over and over until it breaks loose.
Old Jan 15, 2007 | 06:55 AM
Bradstard's Avatar
I was not not able to get it off using the regular Craftman impact gun that came with the compressor. I used this:
http://www.harborfreight.com/c...=2623
It came off without a problem.
faran
Mar 30, 2010 05:09 AM
tinyscivic
Feb 27, 2010 10:25 PM
taterbug
26
Mar 29, 2009 04:29 PM
uncald4
19
May 15, 2005 06:31 AM
MCP486
Apr 1, 2003 09:48 AM
