Injector Question
Old Jan 14, 2007 | 05:06 AM
turbovybez's Avatar
Default Injector Question
Just a quick, real quick question. I was wondering if the injectors from the D16y8 are the same as the ones from the D16y7. I believe those are the two vtec engines for sohc. please correct me if I am wrong. If not I was wondering if the injectors from the D15b7 would be compatible in the y8 because someone told me that in order to convert the y8 to obd-1 I would need the obd1 distributor and injectors. Also has anyone ever done business with http://www.rywire.com. Okay so maybe this question was not so quick. sorry.
Old Jan 14, 2007 | 08:36 AM
gezzuzz's Avatar
Default Re: Injector Question (turbovybez)
all D and B series injectors for odb1 and obd2 are that same size and can be interchanged. only difference is the plugs.. you can simply put obd-1 plus on a obd2 harness and they will work fine.
Old Jan 14, 2007 | 10:02 AM
Hybrid-Fusion's Avatar
Default Re: Injector Question (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">all D and B series injectors for odb1 and obd2 are that same size and can be interchanged. only difference is the plugs.. you can simply put obd-1 plus on a obd2 harness and they will work fine.</TD></TR></TABLE>
Damn! Beaten to the punch!
Old Jan 14, 2007 | 10:05 AM
turbovybez's Avatar
Default Re: Injector Question (Hybrid-Fusion)
Thanks guys.
Old Jan 14, 2007 | 10:06 AM
Jakester9500's Avatar
aren't the y7 injectors a smaller cc than the ones of the y8? I was thinking the y7 injectors were around 180cc and the y8 was 240cc.
CD5-97
Jul 7, 2013 07:11 PM
LS_VTECteggy
Aug 28, 2011 09:17 PM
tissimo
Jan 7, 2005 09:44 AM
chris@allmotor.net
Oct 19, 2003 04:39 PM
94cxHybrid
Aug 29, 2001 11:27 AM
