Injector Question
Injector Question
Just a quick, real quick question. I was wondering if the injectors from the D16y8 are the same as the ones from the D16y7. I believe those are the two vtec engines for sohc. please correct me if I am wrong. If not I was wondering if the injectors from the D15b7 would be compatible in the y8 because someone told me that in order to convert the y8 to obd-1 I would need the obd1 distributor and injectors. Also has anyone ever done business with http://www.rywire.com. Okay so maybe this question was not so quick. sorry.
Re: Injector Question (turbovybez)
all D and B series injectors for odb1 and obd2 are that same size and can be interchanged. only difference is the plugs.. you can simply put obd-1 plus on a obd2 harness and they will work fine.
Re: Injector Question (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz »</TD></TR><TR><TD CLASS="quote">all D and B series injectors for odb1 and obd2 are that same size and can be interchanged. only difference is the plugs.. you can simply put obd-1 plus on a obd2 harness and they will work fine.</TD></TR></TABLE>
Damn! Beaten to the punch!
