Does anyone know how to bring your emissions down before i smog?
Old Jan 13, 2007 | 08:02 PM
zipoton's Avatar
Default Does anyone know how to bring your emissions down before i smog?
I Have a 92 civic ex V-tec but my car failed smog only cuz the emissions are too high at 15mph does anyone know what can cause the emissions to be higher than normal please let me know thanks.
Old Jan 13, 2007 | 08:03 PM
Syndacate's Avatar
Default Re: Does anyone know how to bring your emissions down before i smog? (zipoton)
How many miles? - And is it bone stock? If not, what modifications are done to it (be specific)?
Old Jan 13, 2007 | 08:14 PM
zipoton's Avatar
Default Re: Does anyone know how to bring your emissions down before i smog? (Syndacate)
when i got it they guy told me they slapt a newer engine on it with 30,000 miles on it if im not wrong its should be near the 50,000 mark now the odometer reads 140,000 and it had a ecu for an automatic but last month i got the right ecu for it the p28 another thing i noticed is they took the air conditioner out of the car and the power steering too but no other modifications everything else is stock.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">How many miles? - And is it bone stock? If not, what modifications are done to it (be specific)?</TD></TR></TABLE>
Old Jan 13, 2007 | 08:15 PM
deadline's Avatar
yo..just got done with that problem wut i did wuz i just bought a new CAT.....or the other way is drive the car hard warm it up for a long time before u smog and u should be good......also...where did u fail at (HC) or (CO) or (NO) I'v been there before....
Old Jan 13, 2007 | 08:19 PM
zipoton's Avatar
Default Re: (deadline)
i failed at HC and NO at 15 MPH only at 25 it passed everything my HC (PPM) it says max is 130 i measured 194 and the NO (PPM) max is 835 i measured 1775 theyre prety high anymore infromation you know let me know please.
Modified by zipoton at 9:37 PM 1/13/2007
Old Jan 13, 2007 | 08:49 PM
nicko360's Avatar
* B A N N E D *
change the oil before the test and put in some of that "guaranteed pass emissions formula" it cost like 8 bucks
Old Jan 13, 2007 | 08:52 PM
zipoton's Avatar
Default Re: Does anyone know how to bring your emissions down before i smog? (nicko360)
Yeah i did a whole tune up on it i changed the fuel filter the oil filter the pcv and everything else a tune up consisit of but i didnt put that formula ill put some on asap good looking dawg.
Old Jan 13, 2007 | 09:24 PM
h22apwrdcivic's Avatar
here is a guarantee to pass method i use all the time....
go to walmart
go to the hardware section
find the paint thinners
there is a quart sized tin can called S-L-X Denatured alcohol. (blue and red tin)
put the whole quart into about a half a tank of gas and drive for 30min - 1 hour then go straight to the emissions. guarantee you will pass.
Modified by h22apwrdcivic at 9:50 AM 1/14/2007
Old Jan 14, 2007 | 12:22 AM
Digithalgravel's Avatar
seafoam?
Old Jan 14, 2007 | 10:21 AM
deadline's Avatar
post a pic of the test results..is your timing right ? how many miles on the motor...
Old Jan 14, 2007 | 10:23 AM
deadline's Avatar
++hey i can help u out.. if u knoe modesto area code hit me up 480-2465
Old Jan 14, 2007 | 11:34 AM
1badfox's Avatar
maybe you need new cats(or cat i dont know how many hondas have)
Old Jan 14, 2007 | 07:41 PM
92_ integ's Avatar
on hondas most of the time its a o2 sensor or the catalytic converter.
i would say for sure CAT O2 and TUNE(plugs cap rotor wires)
by the way what was the co reading at?
Old Jan 14, 2007 | 07:45 PM
92_ integ's Avatar
deadline could be right if you failed at 15 and pass at 25, it could be that the tech didnt warm your car enough. cause by the time you get to 25 mph the cat is way hot.
Old Jan 14, 2007 | 08:34 PM
ok well if you wanna cheap quick fix go with what i said earlier, the denatured alcohol burns all the impurities out of your engine(pretty much like you guys that like to use seafoam, except it doesnt get in the oil and ruin ****)
use the denatured alcohol it will pass with flying colors,
i had a 83 s10 v6 with 4bbl holley carb and no cats and straight exhaust, i threw one of those in the tank and the guy at the test center said my readings were "shady" b/c they were like .01 and .002 so dude was like well it passed by my book so i cant say ****.
Old Jan 15, 2007 | 12:44 PM
zipoton's Avatar
Default Re: (Digithalgravel)
dude does it only work between the hour you put the slx or can i put it in today and go smog it tommorow or does it wear off by then get back at me dawg good looking out
Old Jan 15, 2007 | 12:59 PM
kaiba's Avatar
Run two cat If you can get your hand on a VX/CX header. Super low emission and super low back pressure.
Old Jan 15, 2007 | 03:04 PM
Default Re: (zipoton)
honestly i have tried it just the day of, i would rather it be fresh in there when you go through emissions b/c it will be burning mostly the alcohol which burns cleaner, its about the same equivalent as running 116 octane in your tank but not as harsh on the cat.
Old Jan 15, 2007 | 04:58 PM
92_ integ's Avatar
i want to see if that stuff actually works! in my years in smog testing i havent seen it work before. if you put it in and go stright to the test station, maybe.
catalytic converter!
Old Jan 15, 2007 | 05:33 PM
92hatch_cx-t's Avatar
Default Re: (h22apwrdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22apwrdcivic &raquo;</TD></TR><TR><TD CLASS="quote">here is a guarantee to pass method i use all the time....
go to walmart
Are you serious?
Old Jan 15, 2007 | 10:55 PM
EvilPhu's Avatar
Default Re: (sohc dis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 integ &raquo;</TD></TR><TR><TD CLASS="quote">deadline could be right if you failed at 15 and pass at 25, it could be that the tech didnt warm your car enough. cause by the time you get to 25 mph the cat is way hot.</TD></TR></TABLE>
That maybe the problem there, give us the WHOLE test result number.
Old Jan 16, 2007 | 07:10 AM
of course i dont lie about my cheating the emissions laws, id rather spend 4-5 bucks to pass emissions than spend a few 100 to keep trying to pass.
Old Jan 16, 2007 | 08:08 AM
Ahknodd's Avatar
Hey man, I just did this whole thing... My numbers were way crappy and the problem was I had a Bad O2 sensor and that my cat wasn't getting warm enough. So i tested my O2, it was bad, replaced that, retarded my timing cuz that helps for a cleaner burn of the fuel mixture (lower emissions, not as much power though)drove on the freeway for about 30 minutes, and then went strait to I&M. I passed with flying colors.
Basically are you getting kind of poor gas mileage? I was and that was because of my O2 sensor. If you're not then yours is probably good.
I would retard your timing a bit which is easy. If you don't know how then just ask someone on here. I'll explain it if you need.
Then just go for a drive on the freeway for at least 15 minutes to warm up your cat, and then while you're on your way to I&M (or what ever your testing facility is called) keep the engine revving around 2-3K while your stopped. That way you'll keep your cat hot and keep it working right. And if you have to wait in line at the place then do the same thing, keep it revved around 2-3k. You should have no problems.
If that doesn't work then try the SLX stuff and let us know if that works or not. Good luck man!
Old Jan 16, 2007 | 05:12 PM
92_ integ's Avatar
Default Re: (Ahknodd)
catalytic converter and o2!
theres nothing else on most hondas, if it runs good thats all there is to it. cat and o2.
on the timing you could only adjust it +-2 degrees, not much difference.
any more and it fails on the timing check.
Old Jan 21, 2007 | 06:05 AM
zipoton's Avatar
hey dawg the slx stuff worked i finally passed my smog good looking out dawg and everybody else thanks for the suggetions too .
