what's the best way to deal with rusted bolts?
Old Jan 13, 2007 | 06:54 PM
Chief_Rocka's Avatar
Default what's the best way to deal with rusted bolts?
All of the exhaust bolts are rusted and so are the bolts on the downpipe on the header. Any ideas?
Old Jan 13, 2007 | 06:57 PM
nonvteclude's Avatar
Default Re: what's the best way to deal with rusted bolts? (Chief_Rocka)
soak the s**t out of them with wd-40 let them sit. take the biggest wrench you can to it and pull hard.
Old Jan 13, 2007 | 07:18 PM
h22aBB4's Avatar
use a 6 sided socket when you do it, harder to strip the bolts. if that doesnt work, use the trusty dremmel! when I did my exhaust, I had to disconnect the downpipe for the header, unbolt it from the car, then drop the entire exhaust system without dismanteling it, since it was so stubborn.
Old Jan 13, 2007 | 07:22 PM
Yeah I'm about to use my dremel tool.
Old Jan 13, 2007 | 07:41 PM
mlow634's Avatar
WD-40 is junk. You want a product called Fluid Film. You can find it at most john deere dealerships. Stuff works amazing.
Old Jan 13, 2007 | 08:22 PM
TDCTyler's Avatar
pb blaster
Old Jan 13, 2007 | 08:42 PM
saikou's Avatar
Default Re: what's the best way to deal with rusted bolts? (spOolin97)
PB Blaster or any real penetrating spray. Let it soak for 15 min.
Use a breaker bar... chances are, since they're rusted, those bolts are going to break regardless, and pretty easily.
Old Jan 13, 2007 | 08:43 PM
HamiltonRex's Avatar
Default Re: what's the best way to deal with rusted bolts? (saikou)
Oxy-Act torch, heat them till they glow red, then loosen them out! If they dont come out with heat, you wont get them out without breaking them.
Old Jan 13, 2007 | 10:32 PM
l2yanE's Avatar
Default Re: what's the best way to deal with rusted bolts? (HamiltonRex)
pb blaster or the red hot wrench are the only way to go
Old Jan 14, 2007 | 08:18 AM
lude98SH's Avatar
Default Re: what's the best way to deal with rusted bolts? (l2yanE)
i use this stuff called kroil....its industrial stuff they use it at shipyards and other places. I found that it works better than anything else. When i was doing my exhaust i didnt have a torch so i tried PB blaster,seafoam deep creep and WD-40.....none worked well. I used some kroil and i finally got them off.
Also i would maybe get a set of stripped bolt sockets. Because i know for my exhaust the bolts were just crumbling even with 6 pt sockets. I know irwin makes a set you can get them at home depot or autozone and craftsman also makes a set that you can get at sears or even kmart now since they started carrying craftsman tools.
Heres a link for the kroil stuff
http://www.kanolabs.com/
Old Jan 14, 2007 | 09:16 AM
Prudz_lude's Avatar
Default Re: what's the best way to deal with rusted bolts? (lude98SH)
so what happens when the bolts break? i have always wondered this, how do you get the ends out of the block??? You have to put new bolts in so what happens to the other half still stuck in your block?
Old Jan 14, 2007 | 01:31 PM
lude98SH's Avatar
Default Re: what's the best way to deal with rusted bolts? (Prudz_lude)
easy outs
Old Jan 14, 2007 | 02:26 PM
Hondaen's Avatar
Use 6 sided socket and a impact gun.
The impact gun give small torque pulses to loosen, so the chance for breaking the stud is less than using a breaker bar (bigger momentum)
Old Jan 14, 2007 | 06:31 PM
JetSI's Avatar
pb blaster
Old Jan 14, 2007 | 08:15 PM
preludefien
Guest
Posts: n/a
Default Re: (JetSI)
pb blaster and 6 sided socket..
Old Jan 15, 2007 | 07:24 AM
subydoored's Avatar
Default Re: (preludefien)
a torch thats how i got my cat off really easy 5 mins and your done
Old Jan 15, 2007 | 11:16 AM
lude98SH's Avatar
Default Re: (subydoored)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by subydoored &raquo;</TD></TR><TR><TD CLASS="quote">a torch thats how i got my cat off really easy 5 mins and your done </TD></TR></TABLE>
What kind of torch ? I have heard you really need an oxy-acetlyne torch for that ? Which are kind of pricey.
Old Jan 15, 2007 | 11:26 AM
darkspector2.0's Avatar
if you have a torch the heat is the key, propane should work just as well, might take longer as it's not as hot
Old Jan 15, 2007 | 12:18 PM
Default Re: (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">What kind of torch ? I have heard you really need an oxy-acetlyne torch for that ? Which are kind of pricey. </TD></TR></TABLE>
oxygen and propane work too.. But same basic setup, gets expensive.
A normal small propane torch used for pipe soldering etc, may work. Just takes longer to heat up. Make sure its good and red hot!
Old Jan 15, 2007 | 01:18 PM
subydoored's Avatar
Default Re: (HamiltonRex)
an oxy-acetlyne torch thats what i got thanks to my dad and him having every tool on the planet. only thing he doesnt have i wish he did was a tig got the other lol makes working on anything easy.
Old Jan 15, 2007 | 06:13 PM
tmrtwo's Avatar
p and b blaster with mapp gas torch
Zulu888
Jun 16, 2006 05:49 PM
White V6
Aug 3, 2005 08:19 AM
drifter_for_life06
Jun 30, 2005 06:12 AM
94tegdude
Mar 13, 2005 07:25 PM
Sonny
Apr 8, 2002 01:20 PM
