SOHC VTEC SWAP check my list
Old Jan 13, 2007 | 06:23 PM
rbpwrd240's Avatar
Default SOHC VTEC SWAP check my list
Ok so i have a 92 accord, i want vtec and i just snaped my cam and trashed the head. This after my friend hydro-locked the previus motor. both were F22A1's. I know the F22b1 fits and i think if its pre 96 its obd-1. So as far as i know these are the parts i need.
1. f22b1 OBD 1 vtec short block
2. POA ecu OBD 1
I think there are three pinouts vtec ground, vtec oil press, and vtec something.
Here is where i need help, the pinouts on the ecu, is there two or three becouse iv heard of both; also my coil is external is an OBD-1 F22B1 an external coil also or will i have to get an internal distributor and ad the wires into the harness?
Please iv looked i just want the anwser from someone who has done this and knows it forwards and backwards. The post's i find are misleading and have to many i think this does it?
Thanx in advance for your help
Old Jan 13, 2007 | 09:09 PM
rbpwrd240's Avatar
Default Re: SOHC VTEC SWAP check my list (rbpwrd240)
bUMP 4 ur HELP pLeAsE
Old Jan 14, 2007 | 09:23 AM
BlUAc's Avatar
well you can keep your ex dizzy and are you keeping to block and swapping the head or the whole motor? i got lost in your question and yes you will need to wire up vtec.Vtec is A4 and Vtec pressure switch is D6. The black wire in the vtec pressure switch goes to ground.
and if you gotta swap pins a6 and a11 cuz the POA ecu has the o2 and egr swapped if your using that ecu
Alao the intake and exhaust manis are different
Old Jan 14, 2007 | 06:35 PM
rbpwrd240's Avatar
Yah im sapping the whole engine. What do you mean swap the pins for the POA. do you litteraly pull one and put it in the others place. Also how can i get pins out of ecu pin block without a honda tool.
Old Jan 14, 2007 | 06:43 PM
gianinline's Avatar
f22b1 is external coil.
Old Jan 14, 2007 | 06:53 PM
rbpwrd240's Avatar
Default Re: (gianinline)
So then swap the wires for POA obd-1 and wire in vtec and your off and rolling with stocck f22a mounts hoses tranny clutch etc.
Old Jan 14, 2007 | 07:01 PM
gianinline's Avatar
Motor mounts, hoses and such are pratically the same, because you are dealing with another F22 motor. It would only be different if the motor was coming from another type of vehicle, where the engine sits in a different way and the radiator is set further back and such.
Old Jan 14, 2007 | 07:51 PM
Bboy_Trevstuh817's Avatar
I have the same swap as well, use your f22a1 driver side motor mount so you don't have to cut, even if your using a chipped p06 or p28 still swap pin a6 and a11 around for the car to start!
Old Jan 14, 2007 | 09:34 PM
rbpwrd240's Avatar
Default Re: (Bboy_Trevstuh817)
ok so all i need is
1. F22b1 OBD-1
2. PO6,P28,POA ecu
3. wire two wires for vtec ground, and pressure
4. swap pins A6 and A11
Then the car will be 100 percent complete and the distrbutor is the same as a 92 (external coil). Once again i just like to check all my bases before going into a build. After building i will be selling the car.
92 accor 1.6 vtec h/i/e and pullys. Srtuts with coil overs konig wheels 15", projectors,altezas,limo tint, clutch stg 3, auto-manual swap, and indiglo gauges, also have strut bars (not on car negotiable) custom graphics (removable)
Funny i spent so much time and money getting it where my friend wanted it and now im going to finnaly do it right as i have to sell it. Darn shame.
Anyway im looking for about 3,500 sound about right to yall 60k-80k on motor?
Old Jan 15, 2007 | 12:12 PM
rbpwrd240's Avatar
Default Re: (rbpwrd240)
bump for knowledgeable help
Old Jan 15, 2007 | 12:20 PM
Andryzzle's Avatar
do you want my old POA? 94 Ex.
Old Jan 15, 2007 | 04:52 PM
rbpwrd240's Avatar
Default Re: (Andryzzle)
yah i want it let me know how much.
Old Jan 16, 2007 | 09:01 AM
rbpwrd240's Avatar
still oking for helpfull input please no one has told me that im correct on the swap parts list.
Old Jan 16, 2007 | 04:55 PM
BlUAc's Avatar
yes engine, ecu, and wiring of vtec. p28 or poa
only the p0a ecu is different needing the a6 and a11 swapped
Old Jan 19, 2007 | 01:45 PM
vtec92accord's Avatar
man i tell you what i am having problems i got a good deal on a f22 b 400 bucks it has 40 000 miles and its out of a 96 but i am running into alot of problems i need new ecu wiring harness and some more good luck
hondaman1992
Dec 16, 2011 12:07 PM
ludatic98
Feb 5, 2009 11:50 AM
93f22a6
Mar 8, 2004 03:19 PM
Magick211
Aug 1, 2003 06:56 PM
