Headlights problem??????
My dim lights dont work. Well only the passanger side does. My brights work perfectly fine. My question is, How do i re-wire them so they work OR should i take it to a dealership and have them do it? Im getting HIDs here in the next 2 wks, So after i install those, would that fix the problem or what?
Modified by JdmEj1! at 6:56 PM 1/16/2007
What kind of car do you have? It might be loose... my 95 ej1 was always loose for some reason. Some of my buddies have the same problem as me too. a little jingle here and a jiggle there and it was back on. Or your bulbs might just need replacing.
The ground wire on that side is loose. I've seen it quite a few times.
Find the ground wire on the side that is dim, and either tighten it, clean it off, or put it somewhere else and it'll brighten right back up. It should be held down with a small bolt on a ring terminal, thin black wire.
ya i drive a 95 coupe... ok cool guys i'll check it out tomorrow when i can see and let u know if it worked. THANKS!
i love ht lol helps a **** load
uh well i check the ground, even spliced into it and ran another wire, it didn't work. Then there was a bunch of gunk in the black connector that connects to the HL, i cleaned that, and still nothing. Any other ideas? All fuses r good also...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEj1! »</TD></TR><TR><TD CLASS="quote">uh well i check the ground, even spliced into it and ran another wire, it didn't work. Then there was a bunch of gunk in the black connector that connects to the HL, i cleaned that, and still nothing. Any other ideas? All fuses r good also...</TD></TR></TABLE>
Damnit! I was almost certain it was the ground wire keeping the one light from being as bright as the other. That pisses me off because now I'm stumped.
If you happen to have a voltmeter/multimeter around, can you probe the headlight leads on either light to see if they're getting the same voltage? I wish you luck figuring this out and MAKE SURE you keep updating this thread like you are until you find out the problem as I am pretty curious to see whats going on.
EDIT! I searched around and found this thread...
https://honda-tech.com/zerothread?id=1212147
Check that relay, and see what happens! I'll be excited to see if this takes care of the problem!
ALSO, see if this thread has any interesting information for you...
https://honda-tech.com/zerothread?id=370111
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Shot 50 Cent »</TD></TR><TR><TD CLASS="quote">
cool tomorrow ill look over those threads and see... ya the driver side headlight still doesn't turn on.. only when i use my brights do they both work at the same time
annoy!
annoy!
nah those threads aren't any help... My driver side headlight isn't dim, it just doesn't work! Only the brights do... I tried cleaning the headlight plug out, even tried a new ground wire... still nothing works. Anyone else know wtf is wrong?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Shot 50 Cent »</TD></TR><TR><TD CLASS="quote">Did you try a new bulb? Figure its at least worth saying. </TD></TR></TABLE>
lmfao of course...
lmfao of course...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpkmrtoes »</TD></TR><TR><TD CLASS="quote">no idea... sorry we let you down. lol. uhh... dam... i'm clueless...</TD></TR></TABLE>
Yeah seriously man, I feel ******' bad! There was a few suggestions that I was almost certain were the cause of the problem. I feel like we're all useless here as far as helping this man, and I don't like that feeling one bit! haha.
So to the OP: I am also sorry we let you down, and I REALLLLLLY want to know when you finally figure out what the problem is.
Also, have you checked your fuses? I'm not certain, but I believe that each headlight is on its own fuse. Check the ones in the engine bay fuse box, as well as the fuse box under the dash.
okay, so you sure that nothing works?
if your low beam's line isn't showing any voltage, then the line is fried or cut somewhere....
and since you mentioned your hooking up hids... or retroing in hids....your going to connect the ballasts and other equipment straight up to the battery... so i don't think you should be worrying about it...
you are just going to have to modify some of the wiring... thats all..
you could just go to a junk yard, and find the right harness... i'm sure you can find one... dunno what harness you would need tho.. sorry
ya the hid kit im buying is for my car... And yes i checked all fuses and wiring to the one headlight that doesn't work...i also cleaned the corosion off of it.. still nothing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felliph3 »</TD></TR><TR><TD CLASS="quote">try this!!
E-Z Button FTW
<U>I VOTE BAN Felliph3...300 POSTS OF WORTHLESS ****!</U>
to the OP...I hate to say this, but since you've checked the grounds, cleaned the plug itself...it sounds like a wire got cut somewhere, unless you've got a lot of free time to look for it I'd suggest take it to a stealership...or just ignore it and drive with the highbeams on
EDIT: just read you are soon getting HIDs...I wouldn't worry aboput it too much in that case
E-Z Button FTW
</TD></TR></TABLE><U>I VOTE BAN Felliph3...300 POSTS OF WORTHLESS ****!</U>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEj1! »</TD></TR><TR><TD CLASS="quote">so do hids wire up differently? That's what im not sure of, i've never owned a pair. IF that's the case then im not gonna even mess with it lol</TD></TR></TABLE>
