Re-Torque Head Bolts????
Old Jan 13, 2007 | 05:36 PM
civicjdmb16a's Avatar
Default Re-Torque Head Bolts????
I put together a new engine and i noticed some oil on the corner of where the block and the head meet and i also saw a couple of drops of anti-freeze in my oil pan when i dropped it...should i re-torque it? Are you supposed to?
Old Jan 14, 2007 | 01:15 PM
89s1's Avatar
Default Re: Re-Torque Head Bolts???? (civicjdmb16a)
if you found coolant in the oil then it may be a bit too late.
Old Jan 14, 2007 | 01:55 PM
bart2546's Avatar
Default Re: Re-Torque Head Bolts???? (89s1)
Good chance if you already found it's mixed. You COULD try just draining all the oil, making sure the gasket is not damaged, then re-seal and re-torque but it probably already destroyed it again.
EF'GSRrr91
Jan 27, 2015 07:35 AM
94integragsr
Jun 3, 2006 11:13 AM
tuan...
Oct 19, 2004 07:41 AM
b16 matt
Sep 23, 2004 11:19 AM
