5 speed swap
well did you check your cel codes and about that rattling it could be anything your half shaft not bolted down all the way or the bottom cover to the fly loose, where is it actually coming from
no i didn't check my cel yet. i haven't had time yet. with work and weather, it has been tough. well my half shaft is bolted down. although one of its bolts stripped out as well. it doesn't wiggle at all though. and the flywheel cover is bolted down tightly but i can recheck it. the sound is coming from the tranny area though. it seems as tough it gets louder when i made right hand turns so i may have to check in on my passenger side axle as well.
superstock2
Sep 15, 2006 01:44 PM
projectek
Jul 17, 2006 03:46 PM
