3,000 rpm problem
Old Jan 13, 2007 | 12:38 PM
bluelsvtecda9's Avatar
Default 3,000 rpm problem
i have a 91 ef hatch 1.6 vtec turbo the idel stay at 3,000 the iac is not plugged in if i plug it in the car does not go passed 4,000 rpm but idel gos to normal
Old Jan 13, 2007 | 12:48 PM
oodie's Avatar
Default Re: 3,000 rpm problem (bluelsvtecda9)
You say its turbo what is it tuned with im i assume your getting a check engine light any other codes
Old Jan 13, 2007 | 03:21 PM
Brick Top's Avatar
do you have plugs mixed up? check engine light?
Old Jan 13, 2007 | 06:38 PM
yes light is on i bought car with turbo its only like 5 pounds no plugs mixed up iac not plugged in but before didnt do it
Old Jan 13, 2007 | 07:58 PM
NikoZai's Avatar
IACV not plugged in? why?
Fix all the problems you know of, then tackle the problems you can't figure out.
Also, it's turbo'd - so that means it had to have been somewhat tuned to run boost.
If it hasn't been tuned, or is running a stock ECU, you probably don't want to take the RPMs above 4000 until you do get it tuned. Pretty stupid if you boost untuned.
Could just be a distributor related problem - thats usually where to look if you can't rev past a certain point. Take care of that IACV problem first.
And check the codes to find out what other problems you have.
Old Jan 13, 2007 | 10:11 PM
Default Re: 3,000 rpm problem (oodie)
if i plug the iac then it wont go passed 4 grand with it off then it would drives real good but then the only thing is at idel it stays at 3 to 4 grand
Crazy3rdgen
May 11, 2011 11:14 AM
pimpwagon
May 8, 2008 03:32 PM
itr_dc2
Dec 5, 2004 03:50 PM
cdog19
Feb 23, 2004 05:25 PM
Eluzion
May 12, 2003 06:52 PM
