96 itr brake upgrade...
Old Jan 13, 2007 | 08:03 AM
importfan2's Avatar
Default 96 itr brake upgrade...
well as most of u know i picked up a 98 shell and i went ahead and picked up a 4x114 brake set up as well....just thinking if i wanted to get bigger brakes who and where can i get it...ive seen one person on ht who had it...and they were bein a *** and sayin its a "top secret"...so if my fellow itr friends can chime in that would be great.......
Old Jan 13, 2007 | 11:39 AM
Hooch'n's Avatar
Default Re: 96 itr brake upgrade... (importfan2)
Rock the 4 lug, they are fine. Watch the best motor ITR video, you'll see that the 5 lugs arn't a hole lot better, the stopping distance wasn't that huge. The key is making sure you take advantage of the ABS, because that is the big difference between DC4 and DC2......so make sure you hook that up. Not sure if your running HPDE and Track days, but you could also look at Spoon, Willwoods, etc.
Again, ITR 4 lugs are better the then stock integra..
Old Jan 13, 2007 | 05:17 PM
BlueIntegraBoy's Avatar
The 96 spec brakes are not an upgrade over regular 4x100 Integras. Same size and same calipers. What you can do to upgrade is buy 92-96 Prelude VTEC 11" front rotors and 10.2" rear rotors, then buy ITR calipers.
Old Jan 14, 2007 | 01:46 AM
RagingAngel's Avatar
Default Re: 96 itr brake upgrade... (BlueIntegraBoy)
don't forget to upgrade the master cylinder/booster....
Old Jan 14, 2007 | 01:50 AM
Default Re: 96 itr brake upgrade... (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">don't forget to upgrade the master cylinder/booster.... </TD></TR></TABLE>
All 98-01 Integras have the same MC and BB.
Old Jan 14, 2007 | 04:14 AM
tONE.steR's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">The 96 spec brakes are not an upgrade over regular 4x100 Integras. Same size and same calipers. What you can do to upgrade is buy 92-96 Prelude VTEC 11" front rotors and 10.2" rear rotors, then buy ITR calipers.</TD></TR></TABLE>
That setup is a great street setup.
Here is the 11" rotors w/ itr calipers up front w/ fast brakes 11" rear. off of my buddies car, this is 4x100.. same difference.
Fill's 15" wheels nicely.
Old Jan 14, 2007 | 09:20 AM
Default Re: 96 itr brake upgrade... (tONE.steR)
I don't think I've ever seen a Voltage Blue teg with a JDM front
Old Jan 14, 2007 | 11:12 AM
mugenitrturbo's Avatar
buy my big brake brembo 4x100...mint.....off my dc2........paid over $2500...it's still mint...just moving on to smaller rims..can't use no more...give some good offers......
Old Jan 15, 2007 | 06:10 AM
importfan2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">All 98-01 Integras have the same MC and BB.</TD></TR></TABLE>
dont itr's have a 1in MC.....
Old Jan 15, 2007 | 06:12 AM
importfan2's Avatar
well i knew they were the same size but just had different calipers.....so say if the calipers are the same as a 98 itr...would i just have to buy the LUde ROtors for the front....would that also go the same for the rear.....
Old Jan 15, 2007 | 11:06 AM
mugenracer's Avatar
If you go with prelude 11" rotors and ITR calipers you'll have to shave a little off the caliper as the offset of the lude rotors is slightly off (it'll become apparent where needs shaving when you go to fit them) Here in europe MB6 civic VTi front brakes (282mm) are a straight bolt on job for 96spec front brakes and the calipers/pads are the same as the ITRs. I have the full MB6 set up (front and rear - 262mm discs on the rear but the rear caliper bracket bolt holes are a little too wide and so need drilling out to space them properly) however i fitted 262mm AP lockheed HTSL front rotors with axxis ultimate pads and i cant see any 282mm upgrade being as effective as them, theyre practically impossible to get them to fade and the cold bite would send you through the windscreen if you were belted in. AP have renamed the HTSL rotors to AP Dixel, theyre grooved lightweigh high temp rotors and approx 2/3 the weight of teh stock rotors (but only last maybe 10k miles) but totally worth it for the stopping power!
Old Jan 15, 2007 | 01:24 PM
Hooch'n's Avatar
Default Re: 96 itr brake upgrade... (Hooch'n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n &raquo;</TD></TR><TR><TD CLASS="quote">Rock the 4 lug, they are fine. Watch the best motor ITR video, you'll see that the 5 lugs arn't a hole lot better, the stopping distance wasn't that huge. The key is making sure you take advantage of the ABS, because that is the big difference between DC4 and DC2......so make sure you hook that up. Not sure if your running HPDE and Track days, but you could also look at Spoon, Willwoods, etc.
Again, ITR 4 lugs are better the then stock integra.. </TD></TR></TABLE>
my bad, my point is that this is fine for daily and simi tracked car.....no point in upgrading just for Show points imo
Old Jan 15, 2007 | 01:31 PM
NIKE SB'd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importfan2 &raquo;</TD></TR><TR><TD CLASS="quote">dont itr's have a 1in MC.....</TD></TR></TABLE>
Yes, and so does every other integra
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">If you go with prelude 11" rotors and ITR calipers you'll have to shave a little off the caliper as the offset of the lude rotors is slightly off (it'll become apparent where needs shaving when you go to fit them)</TD></TR></TABLE>
Correct you either need to shave 1/8" off the caliper mounting bracket or else run a 1/8" spacer behind the rotor. Also as an FYI 92-96 Prelude VTEC calipers are IDENTICAL (same part number etc) as ITR calipers.
Old Jan 15, 2007 | 01:36 PM
sheekdude's Avatar
From personal experience, the itr 4x114 stops way better the gsr/civic si's.
Old Jan 15, 2007 | 01:41 PM
NIKE SB'd's Avatar
Default Re: 96 itr brake upgrade... (sheekdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheekdude &raquo;</TD></TR><TR><TD CLASS="quote">From personal experience, the itr 4x114 stops way better the gsr/civic si's.</TD></TR></TABLE>
From personal experience, it's the EXACT SAME brake setup except for hubs and rotors. Your pads may have been different or else your brain is broken
Old Jan 16, 2007 | 08:30 PM
obd-0-4life's Avatar
are those Stern Aguzies?
Old Jan 16, 2007 | 10:21 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: 96 itr brake upgrade... (obd-0-4life)
Yep, '96 ITR calipers are exactly the same as LS/GSR calipers. This has been confirmed only a gillion times.
Old Jan 16, 2007 | 10:56 PM
tONE.steR's Avatar
* B A N N E D *
Default Re: 96 itr brake upgrade... (NIKE SB'd)
Thats not true, only some tegs come w/ 1" MC's its varies.
The majority of dc2's have 15/16th MC's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obd-0-4life &raquo;</TD></TR><TR><TD CLASS="quote">are those Stern Aguzies?</TD></TR></TABLE>
Yes
Old Jan 16, 2007 | 11:08 PM
Suspetise...
I was under the impression that '98-01 'tegs had the 1" dealie, and the older ones had the 15/16" dealie.
Old Jan 16, 2007 | 11:20 PM
tONE.steR's Avatar
* B A N N E D *
Default Re: 96 itr brake upgrade... (Stinkycheezmonky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky &raquo;</TD></TR><TR><TD CLASS="quote">I was under the impression that '98-01 'tegs had the 1" dealie, and the older ones had the 15/16" dealie.</TD></TR></TABLE>
I've own a 4 gsr that had a 1" MC, I have a friend w/a 95 gsr w/ a 1" MC.
Old Jan 16, 2007 | 11:22 PM
Suspetise...
Interesting...
Old Jan 28, 2007 | 08:22 PM
ludeboom's Avatar
i was under the impression the 92-96 preludes were a bolt pattern of 4x114 and all 4 lug civic/integra are 4x100.
how do the 11" prelude vtec rotors fit 4x100 integra hubs if this is the case?
Old Jan 28, 2007 | 09:43 PM
Seedc2's Avatar
people usually have them redrilled to 4x100.
so now I am curious.. are 92-96 ludes 4x100 or 4x114
Old Jan 28, 2007 | 09:46 PM
tONE.steR's Avatar
* B A N N E D *
Default Re: (Seedc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seedc2 &raquo;</TD></TR><TR><TD CLASS="quote">people usually have them redrilled to 4x100.
so now I am curious.. are 92-96 ludes 4x100 or 4x114</TD></TR></TABLE>
92-96 ludes are 4x114
Old Jan 28, 2007 | 10:20 PM
TheMuffinMan's Avatar
He knows where you live!
Accords are 4x114 as well, if you check out our FAQ section there's the "big brake" upgrade along with some other stuff.
Accord Wagon Rotors are 11" or so vs the 10" and legend calipers will work as well but it's all listed there
Black Beard
Jun 6, 2009 06:38 AM
formervendor
16
Mar 28, 2007 11:40 AM
egtype-r
Oct 4, 2005 12:11 PM
Cvic90
Nov 7, 2004 11:25 AM
Quik Chris
41
Apr 19, 2003 05:54 PM
