ITR intake cam with JRSC?
Old May 15, 2002 | 04:31 AM
jabroni95gsr's Avatar
Default ITR intake cam with JRSC?
Should i leave it in? Should I bother to change it back to the stock one? Will it really make a difference?
Thanks in advance.
(JRSC - soon)
Old May 15, 2002 | 06:31 AM
salt's Avatar
Default Re: ITR intake cam with JRSC? (jabroni95gsr)
I'm running the JRSC with an ITR. The good thing about it is with good valve springs you can keep making more power from 7500-8800 RPM. I dont know if this is a function of the INT or EX cam though. And cam gear tuning may lead to more power than either cam...
Steve
Anyone else agree?
Old May 15, 2002 | 09:21 AM
Default Re: ITR intake cam with JRSC? (salt)
TTT
Old May 15, 2002 | 10:42 PM
Muad'Dib's Avatar
Corr Performance Pilot
your car doesnt need help taking air in... so you'll see that the Intake cam wont make that much of a difference. Now... as far as expelling the gases out from your car .... this is where the exhaust cam from the ITR works better in expelling gases from your engine. Hope this helps.
Old May 15, 2002 | 11:47 PM
BHSCGSR's Avatar
Do either an ITR exhaust and intake cams or just an ITR exhaust cam. Then get a good set of gears and dial out some overlap......
Old May 16, 2002 | 12:18 AM
csufweed's Avatar
Default Re: ITR intake cam with JRSC? (BHSCGSR)
bottom line is you need cam gears to dial out overlap... overlap is bad on superchargers!! on turbos, its not as big a deal...
bigjon1378
Mar 9, 2015 10:50 AM
daredevil003
Jun 17, 2005 01:20 PM
Silverbeast
Dec 29, 2003 09:13 AM
jabroni95gsr
Mar 11, 2003 09:17 PM
MRDC2
Jul 4, 2001 03:02 PM
