what happen
i just came back from driving my car and then on the way back i decided to step on it and i noticed that it didnt run how it use to anymore its like i was stepping on it and that car was accelarating slowly it was getting speed slowly to then when i got home my rpm's dropped alot like if car wanted to die what could it have been i had just seafoam my car too like 5 hours ago to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oodie »</TD></TR><TR><TD CLASS="quote">Did you use it properly because if not it can harm motor too.</TD></TR></TABLE>
true. alot of times people put to much in or dont change the oil after doing it ,or dont get it all out..is it still smoking ?
i just came from driving it and yeah its still smoking but then i noticed that when i get to a red light and stop my car is struggling to stay on and then it dies what is it could it be that seafoam stuff wtf its like instead of my car running better it runs slower
Modified by kixcrx at 4:17 PM 1/13/2007
you have to get it out..didnt you read the instructions? drive around for a while and make some pulls with the car untill that stuff is gone,,then i would reccomend changing the oil tommorow if you put some into the oil crankcase
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker »</TD></TR><TR><TD CLASS="quote">you have to get it out..didnt you read the instructions? drive around for a while and make some pulls with the car untill that stuff is gone,,then i would reccomend changing the oil tommorow if you put some into the oil crankcase</TD></TR></TABLE>
... isnt that seafoam like that 5 min cleaning **** that gets the gunk out of the crankcase and **** ... if so your suppost to change your oil after you use that and if im not mistakin it says dont drive or put load on the engine withthat stuff in it?
change your oil tomrrow if you havent done so already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1991 CRX Si »</TD></TR><TR><TD CLASS="quote">
change your oil tomrrow if you havent done so already</TD></TR></TABLE>
im not sure if seafoam removes gunk,but i know it removes carbon...How i do it is put some in gas tank,some in the oil crankcase,..Then you put some into the brake booster vacuum not to much though it still has to be able to run,,then after your done turn it off and let it sit for a couple minutes..Then turn it on and make some pulls through out the rev range untill that **** is out...It doesnt say to change the oil but common sense kicks in when you see how thin it make your oil.
change your oil tomrrow if you havent done so already</TD></TR></TABLE>im not sure if seafoam removes gunk,but i know it removes carbon...How i do it is put some in gas tank,some in the oil crankcase,..Then you put some into the brake booster vacuum not to much though it still has to be able to run,,then after your done turn it off and let it sit for a couple minutes..Then turn it on and make some pulls through out the rev range untill that **** is out...It doesnt say to change the oil but common sense kicks in when you see how thin it make your oil.
yeah my oil is thin but i didnt pour it into the oil i sprayed it into the vaccuum lines on the IM i got the spray can one seafoam i dont know but i had messed with the idle screw to get a better idle like 2 days ago could that had been it or nah
ooo i c i was thinking of some other stuff i was thinign about the engine cleaner that **** that suppost to clean out your engine in like 5 min of sludge and carbon...
my car seems like it wants to die when i stop like the rpm drop like its going to shut off then oil light comes on when going to die then give it a little gas and oil light comes off i think its probably i put to much of that stuff into it and its still in there
philosofy1
Dec 17, 2006 05:29 AM
sshaikh01
38
Feb 27, 2004 05:24 PM
