B20 Vtec............
Ive been looking at alot of options for my DA, i think im going with B20 Vtec. I just want to get all my facts straight before i dive into this. Im looking at a B16 head and obviously a B20 block. I found a kit that gives u the oil lines the head gasket the dowl pins ect. Its a bolt up kit, no machine work involved. I want to know if this will work, and what do i need to look out for( problems concerns). I want to hear from people that have this set up/people that have done this before.
Modified by P.O.S_DA9 at 11:51 AM 1/16/2007
I just put together an LSVTEC with the Golden Eagle kit. Very simple and straightforward, if you are mechanically inclined in the least.
Nope. I just had to run a single wire for the VTEC solenoid. The car was running an S100, so I disabled the VTEC pressure check. You will need an OBD0-OBD1 conversion harness and an OBD1 distributor-if you want to run Hondata or Crome.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">Nope. I just had to run a single wire for the VTEC solenoid. The car was running an S100, so I disabled the VTEC pressure check. You will need an OBD0-OBD1 conversion harness and an OBD1 distributor-if you want to run Hondata or Crome.</TD></TR></TABLE>
so i would be better off getting an obd1 b16 head? What OBD r the b20 blocks( do they have a crank position sensor or anything)
The OBD of the head does not matter-you can bolt up an OBD0 head to an OBD2 engine and still use all of the sensors. Many of the B20 blocks available are OBD2, which is not a problem if you are running OBD0 or OBD1 ECU's and wiring.
Bump...........................So ive priced a block. Its a B20B. Now i need to know what ecu and head to run. I want to be able to tune it so it needs to be obd1. What tranny can i run on a b20, i want to keep it cable clutch. Will my 91 LS tranny work?
http://www.theoldone.com/articles/badtothebone/
My favorite B20 build article.. notice how they weld in block posts for added cylinder wall support...
801jdmek4
Mar 20, 2007 11:53 PM
