okay..just searched...nothing..wut is the differences between (sohc) y8 and z6 head ?
Old Jan 12, 2007 | 06:26 PM
deadline's Avatar
Default okay..just searched...nothing..wut is the differences between (sohc) y8 and z6 head ?
look up ^^
Old Jan 12, 2007 | 06:35 PM
deadline's Avatar
come'on no one cant answer this quest.......
Old Jan 12, 2007 | 06:42 PM
pdiggitydogg's Avatar
didnt search too hard...
https://honda-tech.com/zerothread?id=1387386
https://honda-tech.com/zerothread?id=1106299
https://honda-tech.com/zerothread?id=229705
https://honda-tech.com/zerothread?id=385741
Old Jan 12, 2007 | 07:10 PM
Syndacate's Avatar
One's OBD-II and one's OBD-I .
Any serious differences? None really.
If you consider it part of the head, the Y8 IM tends to flow a bit better, but nothing really noticable (a header for a d-series will yield more power than a Y8 IM swap)
The compression on the Y8 is 9.76 compared to the Z6's 9.14. Though that's the whole motor, I'm not sure what that is in terms of specs of the head.
PS:
The Y8 oil pumps suck, usually resulting in spun bearings on high end Y8 setups. If you're going to do a Y8 build, get an aftermarket oil pump.
Also, as "factory specs" - the Z6 puts out 125hp at the flywheel, and the Y8 puts out 127hp at the flywheel. Those number differences are pretty null at the wheel hp numbers though.
Old Jan 12, 2007 | 07:27 PM
...the reason the y8 has higher compression is because of the shape of the combustion chamber - square
gutted-dx
Feb 13, 2005 02:10 PM
tai93si
Jan 16, 2004 07:36 AM
BlackFrog
Aug 29, 2003 03:23 PM
LegendLS95
10
Oct 18, 2001 07:45 AM
