D16Y8 OR D15B7
You don't convert the Y8 harness, you convert your stock harness to the motor. Since you are already MPFI you will have to extend some wires and add in the VTEC wiring. You lucked out with the Y8 as the distributor flange is the same as the D16A6 family of heads so you can use your stock distributor.
if you want any y8 parts let me know. i just bought 2 y8 motors, i have an auto and manual intake mani along with one engine harness, clutch with flywheel, oil pans, let me know if you want. i am keeping the heads. one was blown through the block when a con rod snapped. other one has good block. 8 good pistons and such.one good crank too. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 »</TD></TR><TR><TD CLASS="quote">if you want any y8 parts let me know. i just bought 2 y8 motors, i have an auto and manual intake mani along with one engine harness, clutch with flywheel, oil pans, let me know if you want. i am keeping the heads. one was blown through the block when a con rod snapped. other one has good block. 8 good pistons and such.one good crank too. good luck
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seatown »</TD></TR><TR><TD CLASS="quote">^you selling the b7 engine?</TD></TR></TABLE>
Come on guys, let's not turn this into a FS thread and get it locked
PM's were installed for a reason.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seatown »</TD></TR><TR><TD CLASS="quote">^you selling the b7 engine?</TD></TR></TABLE>Come on guys, let's not turn this into a FS thread and get it locked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicK20 »</TD></TR><TR><TD CLASS="quote">i'll try to find a y8 harness how can i converet to obd0</TD></TR></TABLE>
You don't do that. It's half-assed and won't run right.
Ideally, you'd convert to OBD-2 and run a P2P ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">
PM's were installed for a reason.</TD></TR></TABLE>
sorry, to be honest i thought it was okay because i see it so much in these types of threads. i thought it was the norm but now i know im wrong. thanks for setting me striaght. I will pm from now on. sorry about that and have a good one!
PM's were installed for a reason.</TD></TR></TABLE>sorry, to be honest i thought it was okay because i see it so much in these types of threads. i thought it was the norm but now i know im wrong. thanks for setting me striaght. I will pm from now on. sorry about that and have a good one!
eltexmexalex
Aug 17, 2015 03:02 PM
Josh_ridesbikes
Aug 9, 2012 02:28 PM
