2000 SI.. idle problem after oil change
Old Jan 12, 2007 | 11:18 AM
gotnos2's Avatar
Default 2000 SI.. idle problem after oil change
I have a 2000 Si..stock ecu, stock everything on motor except aem cold air..
The car was due for an oil change and ran fine up to the oil change.. Now CEL comes on, and sitting at stop, idle surges up and down.. from about 200 to about 1400rpm..
Im thinking possible IACV.. but why would it run fine until oil change then all of a sudden do this?.. Anyone ever have this problem? I will go out and check to find out what it is coding for..
Old Jan 12, 2007 | 11:49 AM
gezzuzz's Avatar
Default Re: 2000 SI.. idle problem after oil change (gotnos2)
the iacv is working.. thats why it going up and down.. its penning and shutting.. make sure no vacuum lines got disconnected.. did you touch the idle screw? opening it too much can case surging
Old Jan 12, 2007 | 12:09 PM
gotnos2's Avatar
no, i didnt touch the idle screw at all.. Im thinking maybe a vaccum line got disconnected..
I need to find out what it is coding for and go from there i guess...thanks man
Old Jan 12, 2007 | 12:20 PM
philosofy1's Avatar
Default Re: (gotnos2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotnos2 &raquo;</TD></TR><TR><TD CLASS="quote">no, i didnt touch the idle screw at all.. Im thinking maybe a vaccum line got disconnected..
I need to find out what it is coding for and go from there i guess...thanks man</TD></TR></TABLE>
take it over to a part store and have them run a diagnostic (it's free). they will be able to tell you the code, then if you have any problems come back here with the code.
IMO, it does sound like a vacuum leak. double check you hoses, also can be a MAP sensor issue. when mine went out, it was like night and day.
Old Jan 12, 2007 | 12:32 PM
trrbl1bmx's Avatar
Is the car OBD-1 or 2? Also, make sure that your oil dipstick is all the way down. If you search around in the FAQ you can find what code you have, and how to check it.
Old Jan 12, 2007 | 02:54 PM
gotnos2's Avatar
its a 2000.. so OBD2.. and it coded for 14 which is IACV...
any ideas?.
Old Jan 12, 2007 | 02:56 PM
gezzuzz's Avatar
did you check for a vacuum leak?
Old Jan 12, 2007 | 03:22 PM
gotnos2's Avatar
FIXED&gt;.. thanks to everyone who helped.. im retarded.. vacuum line came off from back side of IM near IACV...
Thanks again, I appreciate it..
Old Jan 12, 2007 | 03:24 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotnos2 &raquo;</TD></TR><TR><TD CLASS="quote">FIXED&gt;.. thanks to everyone who helped.. im retarded.. vacuum line came off from back side of IM near IACV...
Thanks again, I appreciate it..</TD></TR></TABLE>
don't you hate when that happens. atleast it was fast and cheap!
Old Jan 12, 2007 | 04:18 PM
gotnos2's Avatar
yeah exactly.. Im glad it was onlt that problem though..
blaze_125
Jun 25, 2010 05:29 AM
TegraD
Aug 20, 2008 04:49 PM
HUBB
Apr 28, 2004 06:41 AM
JCCOOL43
Oct 2, 2003 12:08 AM
freeplay
Sep 13, 2003 02:16 PM
