brand new battery is dieing
so i just replaced my battery and alternator 2 months ago
and now my battery is dieing like its not getting charged by the alternator
so my question is do any of you have any suggestions on why this might be happening........
thanks
thanks
would that cause it to die when im driving though??
cause the other day i was driving it and all my lights started dimming out...bad like i had to turn my brights on and i barly could see anything.....
then i came up to a stop sign and i slammed on the gas after stopping and when i shifted into 2nd real hard all my lights came back on...
so yeah.
would that still be a short?
so yeah.
get a multimeter and check to see if your charging system is actually charging the battery. see how many volts its getting when the car is at idle...i think its supposed to be around 14...mine was...but if it isnt charging its your alternator, if it is charging your battery or terminals are junk. p.s. if your batter isnt charging check all the connections at the battery, starter, and alternator, then check to see if the fuse for the alternator sensor is blown.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokecdxx »</TD></TR><TR><TD CLASS="quote">then i came up to a stop sign and i slammed on the gas after stopping and when i shifted into 2nd real hard all my lights came back on...</TD></TR></TABLE>
This little fragment of information suggests to me that you have a loose connection or ground somewhere. There's no other logical explanation for that kind of charging system behavior.
where is that sensor fuse at....cause i have looked though my fuse cover lokking for anything that would deall with the alternator.......but havent found anything at all....so maybe im just having a moron moment and im not seeing what you are taling about or im not looking in the right place.
Deffinitely do a parasitic draw test. I mean a basic (and NOT efficient way) to check is to see if anything still turns on when the car is off. Sometimes it's the radio or something stupid like a defroster too. But it still sounds like an alternator problem. I know you just put a new one on but it still could be bad. Was it a rebuild? Also check to make sure your ground and power connections to and from the alternator are secure and tight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokecdxx »</TD></TR><TR><TD CLASS="quote">THANKS EVERY ONE
I JUST FOUND OUT THAT MY 2 MONTH OLD ALTERNATOR WAS BAD
BUT THANKS FOR ALL YOUR HELP</TD></TR></TABLE>
Lemmie guess ... not OEM?
jxhxb
Dec 28, 2009 09:26 AM
samdawgsol
Apr 3, 2005 12:02 AM
GroundZer0 336
Mar 6, 2004 05:55 PM
imnotswapped
Feb 17, 2004 10:03 AM
